Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Saw runs and stops runing - Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
  • Dean
    Dean May 11, 2010
    Need more information. What model etc, when does it stop running?
  • 42 Answers
My guess is that your fuel lines are cracked or have a hole in them somewhere. try installing new lines and let me know how it works.
Posted on Mar 07, 2009
My sthil saw ts400 when is its runing my blade keeps spining all the time and not stop
Try a little light oil when stationary and unplugged. Place oil centre and turn by hand back and forth. Take outside and protecting your clothing and anything in near vicinity switch on fir about min, switch off then in again then off. Switch off, hopefully solved.
Aug 10, 2014 | Saws
How do i open the motor to a black&decker 71&2 inch band saw ? my saw has started to make a lot more noise when runing
There are many reasons why band saw make noise. Here's are some "few checks" to do
1. Run the band saw without blade.
2. Run with a different blade.
3. Run the motor alone.
4. Check the bearings.
Another thing; incorrect speeds and feeds can cause noise and vibration.
Regarding about opening the motor, I can't help you with that. Try to check any other band saw motor manual reference.
I have Trajan 7x12 band saw, no vibration or noisy at all, I use Haltbar blade from sawblade.com
Jun 15, 2014 | Black & Decker Saws
Motor stops runing
Check out the fuel pump
Worn Out
Runs Then Quits,Then Runs
Mar 19, 2013 | 1996 Oldsmobile 88
CHAIN SAW QUITS RUNING AFTER WARM UP
remove the muffler and run it if it runs good without it open the muffler and clean of the screen inside
Jun 06, 2012 | Craftsman 18 Inch 2.6 Ci Chainsaw Tank...
Chainsaw will not stay runing
hello sir,, now there are two types of carb.adjustment screw covers,the old one where there are plastic over the screws,simple remove the plastic covers with a pair of needle nose pliers or cutting off,,,second are the new ones that are above the adjustment screws,which you have to take your drummel tool with the cutting blade and cut slots in the screws, after you get this done it is important to count the number of rotations in until stops make note how many. because you are going to reset the same way.now remove the screws,put to the side when you get ready to put screws in put in all the way than back out as many turns that you noted, now that is factory set there should only be a small adjustment to do. the rule of thumb is turn both out 1 1/4 turn and adjust in until saw runs smooth and idles ok, it is hard to adjust the top speed when saw is running wide open,let saw idle when adjusting top speed is easier that way, when you go to cut wood you may have to readjust top speed, the above does apply some what if you are not using fresh gas mix and dumped out the old fuel and starting with fresh,and a new plug CJ8Y,and as you know the saw has to breath in and out by this i mean a clean air filter,make sure the small screen on the muffler is not cloged,this will keep saw from running at peak speed and sawing wood, ok i have ran across a few saws to where the small screen in the muffler is cloged so the saw would idle but not run at high rpm's,if you do and check all of the above your saw should run,oh btw check compression should be above 60 to 160 lbs, hope this helps,any comments welcome,thank you. ~~
Feb 19, 2012 | Garden
Saw stops runing when it gets hot after cool down start an run fine to it gets hot again
Couple of possibilitys here, when it starts to die slacken off the fuel filler cap, if it then picks up again it is a blocked fuel tank breather, the other possibility is the ignition unit breaking down when hot, the only answer here is to replace the unit.
Sep 08, 2011 | McCulloch Garden
I have homelite UT10560 chain saw. The problem I have is it will start and run when cold. But if the saw shuts off it is very hard to start again. What is the trick to start when saw has been runing...
Make sure you have control set on run,not choke or start. Check spark aresstor by removing exhaust cover and cleaning screen of carbon and oil build up with spray carburater cleaner and fine wire brush.Also remove gas cap and make sure that vent hole in cap is open.Otherwise it can draw a vacumn after being ran for awile and be very hard to start.One last thing is make sure that spark plug gap is correct and that there are no hairline cracks in porcelin insulation. Best of luck. Thank you.
Apr 20, 2011 | Homelite ZR10926 16" Chain Saw
Saw was runing and died now it want crank
My saw also died while running and is now just giving off a gust of air on the hits it would usually crank. Is yours doing this also?
Jan 12, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Feb 08, 2010 | Poulan Pro Chain Saw 46cc 20"
1992 firebird run good then it jist stop runing
Have you changed the fuel filter? Does it start and die right away, or does it take a few minutes?
Aug 19, 2009 | 1992 Pontiac Firebird
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
140 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
