Question about Air Tools & Compressors
I have a compressor and the problem i am having is it will not fill the way its suppose to can you give an idea what could be wrong,it will run for about 8 seconds and it shuts down.
  • 3 more comments
  • goofyzcapric Mar 02, 2009
    pressure needs tobuild to 120 psi.
  • JODY BRIDGERS May 11, 2010
    DROPCORD IS TOO SMALL?
  • josh1111 May 11, 2010
    could be the regulator
    does it have a drain at the bottom of the tank? does it have psi adjustments on it?
  • Dean
    Dean May 11, 2010
    What pressure does the tank fill to?
    Problem Solver:
  • 11 Answers
Check valve stuck open or pressor switch worn or misadjusted
Posted on Mar 25, 2009
Low output pressure from Airmate Compressor
You have this posted in the wrong prioduct category. please re-post
Jun 07, 2012 | Cars & Trucks
My compressor is building to much pressure and blowing out the relief valve. what do I check
You didn't give the model of your compressor so, for an electric model: Check your gages while the tanks are filling. If the pressure gets to the rated high pressure level for your model and keeps going until the relief valve pops, the problem is with the pressure switch. It isn't turning the motor off when it's supposed to. If the relief valve pops before getting to the max pressure the tanks are supposed to be at then the spring in the valve is broken or weakened to where it pops too early. Replace the relief valve.
May 23, 2012 | Air Tools & Compressors
I just got a used 2005 clk500 with 27K miles and airconditioning was working great on way in to work. and at lunch it started blowing hot air no matter what temp i had it at. Any ideas?
You could have a leak in the AC system ... if you just bought the car, the previous owner might have filled the Fre-on just before selling it to you, which would have hidden the problem. If this is the case, take it to a mechanic and they can probably find the problem.
Your compressor might not be compressing properly -- when you put the air on full-cold do you hear the compressor kick on? If not, it might be a bad compressor, or no coolant. Once again, this would require a mechanic to give you all the details
Your AC system might be in perfect shape, but out of coolant anyways. A mechanic should be able to fill it up for you in short order.
Unfortunately, if you are not experienced with working on cars, the AC system is not the safest to be working on on your own. It is highly pressurized when filled with coolant (which is a toxic substance) and without the right tools and experience, you could get severely hurt by loosening the wrong bolt at the wrong time. I highly recommend taking the car to a professional to reduce the risk to yourself.
May 26, 2011 | Mercedes-Benz CLK-Class Cars & Trucks
I have a Goldstar Dehumidifier DH504ELY7 that doesn't pull moisture out of the room. the fan runs and I think I hear the compressor come on but the air coming out the back is cold and the bucket doesn't...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 11, 2010 | Goldstar DH504EL Dehumidifier
Compressor keeps running but no cooling?
Check this video, might give you better idea what could be wrong with that compressor. We cut this one open, found couple issues.
Feb 10, 2010 | Traulsen G10010 Refrigerator
Fans in refer/freezer run continuously
it suppose to run so long the compressor is running it goes into defrost every 8 or 10 hours or it shuts off if it reaches temp but if you can hear the compressor running and the evap fan aint running somethings definitly wrong
Nov 03, 2009 | Kenmore Refrigerators
Tank does not fill to proper psi. tank fills to 60 psi motor keeps running but wont fill to 150 that its supposed too. when i shut off compressor no air leaking????
strip the cyclinder off and inspect the valves if closing and opening also check to make sure you dont have a blown head gasket also on the tank from the pipe from the pump unit is a gold valve you need to open the end off this valve with the tank drained and turn the ruber around with the spring inside and replace this if still doesnt work get back to me bud
Sep 11, 2009 | Air Tools & Compressors
Have a campbell housfeld compressor supposed to shut off at 120 but it blow the breaker after 100 is there a way to lower it so it cuts off earlier then 120? i let my friend borrow it and broke the switch,...
If wires were in the wrong slots you would know once you put power on the unit, the gauge could be damaged and giving you a false reading and the pressure switch may also be damaged.also if you are using an extension chord this may also cause high amp draw.
Jul 16, 2009 | Air Tools & Compressors
Another question
I have the same problem. I believe it is because it has a refrigerent leak. When there is little refrigerent, the begining of the coil will freeze up. I would really suggest calling the manufacturer. It is defintely something to do with this specific model
Sep 07, 2006 | Goldstar DH504EL Dehumidifier
Air Tools & Compressors Logo
148 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
