Question about Hotpoint NVL333EY Electric Dryer
Dryer won't start and it has a burning smell
I have Hotpoint model # NVL333EB3WW, serial # ZD715341W. We think it is the belt but how do we get the top off to check it out?
    Guru:
  • 462 Answers
The top is often screwed down. On yours it may have spring relaeces and screws at the bottom. The springs about 1" to 1.5" wide may be pushed in with a flad blade like a putty knife. Look between the top and the front for these springs from side to side or inset from each corner maybe as much as 8". If it has screws they could be under the lip if it extends under the dryer front. or they could be under the dashwhere the time and controls are mounted.remover the back of the dash for access there. If it has screws there the top may slide or need to be pushed back after unscrewing them. Good Luck
Posted on Mar 17, 2009
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
My hotpoint washing machine won't turn on and when turning knob to on position a strong odor of burning plastic comes out from under it
The burning plastic smell sounds like your belt is worn and the drive motor is heating up to the point where it is melting the plastic. You should make sure the power is off and check the belts, transmission, clutch, and drive motor.
Jul 04, 2012 | Hotpoint Washing Machines
My dryer stopped running in mid cycle and there was a burning smell. I thought it may be the belt, but it is not the belt. Also, the light inside the dryer hasn't worked for years, so I don't think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 15, 2011 | Maytag HYE3658AY Electric Dryer
I have a hotpoint VTD00 tumble dryer and it is heating up but the drum isn't spinning and smells of burning. Thanks, Annmarie
The belt is probably worn out and is slipping,the smell is from the belt slipping on the drum.
Mar 02, 2011 | Hotpoint Dryers
Roper elctric dryer model RES7648EQ make grinding and scraping noise when i start it. Found a bra hook cought in drum on inside of dryer took it out now when I started it it smelled like the belt was...
belts dont really burn the main reason for buring smell is lint on the element did you take the whole barrel out? as 90% of the lint that burns is formed around the heating coil behind the barrel
best of luck sir
Dec 02, 2010 | Roper RES7648E Dryer
I replaced the dryer belt and now it smells like burning rubber
Check for correct belt size and pully tension. it sounds as though the belt is slipping on the pully.
Sep 25, 2010 | Hotpoint NVL333EY Electric Dryer
I have a used GE DCLR333ETOAA model and last time was used it work for few mins. but smell like burn and then stop working. What you think it is?
If the machine quit and won't restart, I would be looking at the drum belt. Some machines will not start if the belt is broken. If the smell you are getting is more electrtical than a rubber smell you need to be checking the thermostats and make sure the venting from the back of the dryer to the outside is not full of lint because the safety thermostat will shut the dryer down so it doesn't overheat.
Jan 24, 2010 | GE Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Hotpoint NVL333EY Electric Dryer Logo
330 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
