Question about PfaFF Creative 7570
Pfaff 7550 foot press doesnt work
7550 foot press does'nt work.
4 Suggested Answers
  • 323 Answers
SOURCE: Foot control for PFAFF won't work
These machines need to be seen by a technician who can disassemble the motors and replace the carbon brushes. You should have them serviced at the same time since it doesn't take that much longer to do everything.
sewman7
Posted on Sep 27, 2008
SewTechWayne
  • 186 Answers
SOURCE: How to stipple with Pfaff 7550
Make sure you have the presser lifter lever in the proper position. When lowering it, push to the rear and it will stop half way down. This engages the upper tension but keeps the foot from lowering down and touching the fabric.
If this doesn't help please post the exact problem, i.e. thread pulling to the bottom etc.
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Does the Pfaff 7550 run on electrics here and other places?
Somewhere on the machine, usually the bottom, there is a switch to change the voltage settings of the machine. Please check that and your users manual for clarification.
Posted on Apr 18, 2009
  • 1116 Answers
SOURCE: Pfaff 7550 pressure foot
The presser adjustment is usually above the presser foot near the top of the machine.
It can be a post on the top of the machine, a chrome screw on the top of the machine.
Check with your Pfaff dealer.
I use the walking foot for this technique...no puckers if the quilt is first basted.
Posted on Mar 18, 2010
Pfaff 7550 presser foot will not go all the way down after using darning foot and returning to regular sewing.
By chance, do you still have the darning foot on the machine? If so, it is shorter than a regular foot which allows space to manually maneuver the fabric.
Also check that the presser foot pressure is activated and the feed dogs are in the up position.
Sep 06, 2016 | PfaFF Sewing Machines
My presser foot "handle" is stuck on my Pfaff Creative 7550, I can't move it to use my machine. I don't see anything wrong, any suggestions?
Yikes! I bet that since it has sat for so long that you have some corrosion not allowing the foot bar to be moved.
Dec 15, 2012 | PfaFF Creative 7570
Mar 18, 2010 | PfaFF Creative 7570
Foot pedal does not function on pfaff 7550
my pfaff sewing machine footpedal sticks
May 24, 2009 | PfaFF Creative 7570
Jan 29, 2009 | PfaFF Creative 7570
sewman7
Sep 20, 2008 | PfaFF Creative 7570
Pfaff 7550
Press the small white number 1 button while turning on the machine. You language selections should appear.
May 15, 2008 | PfaFF Creative 7570
PFAFF creative 7550 sewing machine
batteries went out and los all basic memory. machine cannot sew. cannot choose sticthes. How can I reprogram?
Feb 08, 2008 | PfaFF Creative 7570
Sewing Machines Logo
50 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
