Question about Whirlpool ED2FHSS Side by Side Refrigerator
I have a whrilpool side by side refridgetator, when you close the doors and try to open them again quickly they are very hard to reopen. the model number is ED5VHEXTB01, i bought it at Lowes about 2 years ago and this has been a problem since day one, I thought it would get better but no luck.
Thanks for the previous info peyton!
Try closing the freezer door VERY slowly. This seems to help.
Posted on May 31, 2009
  • 410 Answers
This is a normal occurence and there is nothing that can be done to stop it from happening. what causes it is when that freezer reaches sub-freezing temps it creates a low pressure type condition that causes a vacum. this has always happend on all refrigs but older unit had so many air leaks that the pressure released very quickly and the doors werent hard to open. this vacum condition is a testament to the way the manufacturers have improved the seals and air tightness of newer units.
there are vacum breaks that can be installed on the refrig that can help a little but this also allows air to leak back into the unit and cause a loss of effciency. most times if you will wait 20-30 seconds that vacum will release and the doors will open normally.
Thanks Peyton
Posted on Feb 28, 2009
I open side door window for removing hard disk and removed hard disk then after closed the door properly but sounding alarm from server so what can i do
It seems to be that side door is not properly closed. Please reopen side door close it again. If it still not work, let's clean up dust from sensor and then try again. Also, please check whether hard drives are properly connected or not.
Please let me know if it still does not work.
Regards,
Kaushik Patel
Oct 30, 2013 | Acer Altos G540 Server (G540-50039)
Sub-Zero 601 F - when the door closes is re-vacumn seals and take 3-5 minutes before you can re-open the door. Is this time adjustable to something less? This is very inconvenient when working in the...
Q: Why is my door hard to open?
A: Your unit was designed for an airtight seal.
A vacuum seal can form after the door is closed. Wait several seconds for pressure to equalize before reopening the door.
I have had this problem as well. A quick solution is to put a thick straw between the seal and the unit. this usually makes it easier to open. Don't forget to remove it though.
Mar 27, 2011 | Microwave Ovens
Garage door loses travel settings after a day or two.Door closes then reopens after hitting the floor.I made the proper travel adjustments on the side of the unit then after 1 or 2 days the door hits the...
I have been having almost the same problem. My up limit setting is changing. I intend to replace the limit switch assembly. I know of nothing else that can cause this problem.
Dec 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Why does the door stick if opened,closed and reopened
Hi, what I think your referring to is "suction". If you open the door and then close it when finished but then you decide you want to open it again and it is really tight or "seems" stuck, that is normal and I'll explain why. It's all related to the second law of thermodynamics which states "hot will always migrate to cold" or at least that's the jist of it, we'll keep it light for this lesson, and NO there won't be a test tomorrow lol. What takes place when the door is opened is this. The warmer ambient air which is at room temperature rushes into the fridge, (actually migrating to the freezer/evaporator) and pushes all the cool air out. When the door is then closed a vacuum or suction if you prefer is created via the warm air in the unit being "pulled" to the freezer. This action usually only last's several second's, hence the door will open easy again shortly there-after. Sometimes if you listen closely you can actually hear a slight whistle or whoosh sound from this action occuring, it's actually pretty COOL...pun intended lol. Hope that help's, let me know please. I should also add if the door is just simply opening when at rest or when it shouldn't, check the seal and magnet around the door perimeter. The magnet is just there to insure a good seal,(contrary to some believing it should "pull" the door closed...nope. I mean it will to a small degree, but it just help's keep it closed and insure it seals) but should be in contact with the cabinet perimeter around each section. Good luck. macmarkus :)
Nov 21, 2009 | Whirlpool GD5SHAX Side by Side...
2002 Honda Odyssey: sliding door jolts/reopens when closing
Please check the aft track roller assembly. It is easiest to inspect from the rear of the van looking forward when the door is open. You'll see the rear hinge assembly clearly. The track rollers cannot be seen but you can pull outboard on the rear edge of the door--the door should not move outboard more than 1/8 of an inch. If it moves out more than this or feels sloppy, suspect damaged/missing track rollers. This will cause the hinge to chatter in the track and "jolt". It will also cause the door to misalign during the close phase preventing the close motor from properly engaging.
Replacing this part is no easy task but doable if you are good with cars. Check back here for more details if you want to try it, otherwise get a competent mechanic or the Honda dealership to do it.
Jul 20, 2009 | 2002 Honda Odyssey
Garage door closes then reopens (does not stay shut)
On the side of your opener you will find the down limit control. Using a small screwdriver turn this control in the opposite direction of the arrow printed on the cover. May take some tweaking to get it just right.
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Open and closing problems w/ garage door
First adjust the down limit setting. There is two white screws on the side of the opener. The one that says down needs to be turned to the less side. One full revolution of screw adjusts approx. two inches. Turn it down until the door does not close all of the way and the slightly turn it up until the door closes all of the way with stight pressure on the door. Next there are two blue screws on the back of the opener. they should be on the five setting on both the up and down screws.
Mar 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
159 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
