Question about ASUS Eee PC 1000H Laptop
Key board i cant use the email a to come up keeps getting a dot instead.how do i use it.
  • Richard George
    Richard George May 11, 2010
    Hi, this may sound daft but have you tried holding the shift key down when you press the @ key!
P1000 10.1 polaroid tablet. How can I get keyboard to work?
Hi they r cheep to buy on E/BAY APROX $23. THIS WOULD B THE BEST WAY TO FIND OUT IF IT IS THE KEYBOARD OR YOURE TABET THAT IS AT FAULT CHEERS
Mar 07, 2016 | Polaroid Tablets & eReaders
One key recovery wont run on boot!
Email Lenovo support staff, I thin it is free.
Oct 31, 2017 | Lenovo G550-29583AU Notebook
My gateway laptop keeps typing ........... periods or dots.
moved you out of HP. it's not a hp
the does means the key board is bad.
unplug the keyboard, see, it bad.
gateway is defunct maker now, long gone.
hard to find parts but ebay.
Sep 09, 2017 | Gateway Computers & Internet
Cant find divison sign on calculator
If this a a real calculator then your sign of the division must have rubbed off from the keypad.
So the best way to find is to look at the remaing signs of the -.+ and x. the remaining one will be the division sign other than the = sign.
to confirm divide a sum and get answer to confirm.
Mar 10, 2011 | Office Equipment & Supplies
My keyboard keeps typing WE/EW instead of E, SD/DS instead of D, 32/23 instead of 3 XC/CX instead of C, etc...
hi dont worry it is not any problem just clean ur key board it will be fine. just now only i cleaned, now im not getting that problem
Feb 19, 2011 | Lenovo Keyboard
I can not complete my email address to join the xbox club the symbols for the dot or period do not show when I attempt of enter my email addless
try looking on the key board (on the screen) for the symbol button. it should be one of the triggers on the controller that is used to switch to the symbol keyboard
Jan 26, 2011 | Microsoft Xbox 360 Console
My friend just bought a new Acer Computer, and is having trouble with the keyboard, he cant get the @ .there for he can't access email program or enter email addresses. Please help.
Sounds like the Acer has been installed with or is running the US style keyboard....this means that the @ instead of being as shown is actually available by using the shift key and 2 (it's instead of the " shown)
Get them to change to a UK keyboard via settings and they wont have to improvise!
Jan 01, 2011 | Acer NSK8458AN Keyboard
Timing belt tensioner-white dot instead of pointer. Align how?
belt tensioner does not have to be lined up to anythng as all it does is keep the belt tight.
Oct 13, 2009 | 1999 Daewoo Nubira
Mult.i. bo.o.t screen.... .on .turn o.n and .do.t.s.....
Go to the device mananger. Hold down the windows key and press the Pause/Break key. Go to the Advanced Tab, Then Settings under Startup and Recovery.
You can uncheck to display the startup menu and you can also edit the boot.ini right there.
and remove other boot option that appears at start up
The other thing youve mentioned
means this disabled by infection
now there are 3 software that you should download and run in order to fix this issue and any future infection
1.malawarebytes
2.combofix
3.trojanremover
These are poison pills for such infection also they are freeware
Thanks And Regards
kindly rate this solution
May 13, 2009 | Fujitsu Siemens (MAN3184MCB) Hard Drive
Philips Magnoavox 8p6054 c101 60in rear projection
Change the coolant on the pic tubes, its simple, Remove the 4 screws holding the lense down, use a vacuum and rubbing alchohol to clean, , tilt tv to level individual tubes, refill then reassemble.you can fix one for about 20 $
Have a problem email me" natsp2000 at Yahoo dot Com " no caps, use . instead of "dot", @ instead of "at"
Oct 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
ASUS Eee PC 1000H Laptop Logo
23 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
