Question about Brother MFC 8220 All-In-One Laser Printer
Toner empty error message on brother mfc 8220.
I don't believe the toner is empty. How do I test this and check for real problem?
  • Kazyak Mar 17, 2009
    I keep receiving a "Change Drum Soon" message on the Brother MFC 8220 printer that I use at work. I have changed the toner, but I still receive this message. Printer also leaves skid marks all over the print and fax copy.
  • Anonymous Mar 13, 2014
    toner error in brother mfc 8950
OK
Here's what you do if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Posted on Aug 12, 2009
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
How to replacement drum brother mfc 8220?
pull out the toner cartridge.
The drum is the small caddy that the toner sits into.
May 22, 2011 | Brother MFC 8220 All-In-One Laser Printer
I have a Brother MFC 8220 with a nonBrother cartridge and the original Brother drum. No problems printing until today. I tried to send a 4x6 piece of thin card stock through the front manual feed on the...
There are possibly 2 reasons why this is happening.
1. The drum unit may have been damaged in some way but I doubt it. Check fully that all contacts are in the right place at either side of the drum unit. A contact may be slightly bent.
2. Check the Transfer Roller is in its correct position. The transfer roller is the felt type roller that is positioned in the printer under where the drum unit goes. If this has got out of position then that could also cause the faint printing. Check contacts in printer are not bent.
May 19, 2011 | Brother MFC-8220 Fax
My brother mfc-8220 printer does not want to print. the drum was broken and i replaced it and the toner but yet i hear a grinding sound followed by an error message saying paper jam. I removed the paper...
it might be that the drum replaced is tighter or the space to pass with in the drum is less. friend did u replace the drum of a same model and same type?
May 12, 2011 | Brother MFC-8220 Fax
Brother multifunction laser printer, model #8220 : can you use color ink cartridges with this model or black /white only?
Welcome to FixYa!
The MFC 8220 is a Laser Printer. It uses Toner Cartridge. Product #TN540 or #TN570. It cannot use the regular ink cartridge.
See full details in this link: http://www.brother-usa.com/MFC/modeldetail.aspx?PRODUCTID=MFC8220&tab=supp
Thank you for using Fixya. Jas247
Apr 03, 2011 | Brother MFC 8220 All-In-One Laser Printer
Brother MFC-8220 leaving ink on printed docs. How do you clean that?
That's usually a bad toner cartridge that dumps too much toner per print. Buying a new toner cartridge should fix it. You may need to wipe up a little spilled toner inside. Just use a dry cloth, and be very careful around the little black levers that stick up to detect the paper.
There are other manufacturers who sell toner for these, but some of them have toner inside that's so hard to stir, it breaks the gear in the machine. That makes a very expensive repair for the little money you save on generic toner.
Dec 03, 2010 | Brother MFC-8220 Fax
Imagistics 2500
With that model I believe you have to leave the toner door open and press start
Oct 24, 2008 | Brother MFC-8220 Fax
Toner low message
The only way to clear the toner low i believe is to change the toner.
Jul 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8220 All-In-One Laser Printer Logo
1,257 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
