Question about Jandy Laars Lt 400,000 Btu Heater
Heater doesn't come on
My Jandy LT 400,000 doesn't come on. When I turn it on the blower doesn't come on and in a minute or two the service and high pressure light comes on. What could the problem be and what do I do?
    Top Expert:
  • Jandy Master
  • 6,889 Answers
Check pressure switch and copper tube
Posted on Mar 05, 2016
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 128 Answers
SOURCE: Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Posted on Aug 23, 2009
  • 8404 Answers
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
Re program your assorted timer functions and make sure you set AM and PM or use a 24 hour clock. I think your model allows for a 24 hour clock setting but I am not certain.
I hope this helps you
a
Posted on Oct 09, 2009
  • 246 Answers
SOURCE: My Jandy LT 400k heater shuts off when the fan
my guess is you are a pool guy so im not going to awser this one
Posted on Oct 15, 2009
  • 246 Answers
SOURCE: getting error code 188E on Jandy Model LT Lite 2
press the arrow key for 10 sec this will reset the heater. if code replace control board, if not enter time date and set temptures for pool and spa
Posted on Oct 16, 2009
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
HEATER IGNITES AND WORKS FOR A FEW MINUTES, THEN SERVICE LIGHT AND AIR FLOW LIGHT COMES ON
either air flow switch is faulty, blower isnt producing enough air pressure or blockage in venting
Mar 17, 2013 | Jandy Laars Lt 400,000 Btu Heater
The heater turns on for 20 seconds then shut off then the air flow swich blinks
either faulty air flow switch, blower not producing enough pressure, blockage in venting, blockage in air switch tubing
Jul 26, 2011 | Jandy Laars Lt 400,000 Btu Heater
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Service light and ags light comes on after a minute or two
I had this problem. Jandy ended up replacing the burner from day 1 with the heater (LT400 propane). It was a manufacturing defect. Of course it took 5 trips from the "warranty" company to not fix it before they finally punted to Jandy. Then, there's only one Jandy service rep from VA to ME (I'm in PA).
Jan 27, 2010 | Jandy Laars Lt 400,000 Btu Heater
BLOWER MOTOR REAL HOT
You probably have a shorted starting capacitor. Unless you are familiar with this kind of electrical repair, you should leave this to a professional.
Oct 08, 2009 | Jandy Laars Lt 400,000 Btu Heater
Hi Lim SW fault when trying to heat pool.It is a Laars lx 400,000
heater over heated check gas pressure then replace high limits also make sure chemicals in balance
Jun 06, 2009 | Jandy Laars Lt 400,000 Btu Heater
Blower rus, igniter lights up but no flame. gas is good
check for 24 volt at gas valve when you turn it on if 24 volt replace gas valve if 24 replace ign module
May 25, 2009 | Jandy Laars Lt 400,000 Btu Heater
Jandy Laars Lt 400,000 Btu Heater Logo
117 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
