Question about Oster Golden A5 1-Speed Universal Motor Clipper 78005-010
Oster Golden A5 Clippers will not cut
My #10 blade will cut sporadically. Sometimes they will working and then quit cutting hair.
My #3F blade? (longest hair) works well, but when I put on a attachment to cut longer hair, they do not cut.
thks for your help
  • 1 more comment
  • apegg May 11, 2010
    When you say they wont cut does the clipper stop working or does the blade just not cut?
  • Patsey Roberts Aug 18, 2013
    I was in the middle of clipping my Shih Tzu one day and my clippers just stopped cutting. I made sure they were oiled and brushed them out really good and they still wouldn't cut. Seems if they were getting dull it would at least not cut them very well but to stop mid stream. Please let me know what you think. I have a very shaggy Shis Tzu that needs a hair cut.
  • Anonymous Mar 26, 2014
    pulling not cutting
These kinds of clippers are fussy about oiling and dirt. It is essential that the blades be spotless and well oiled FREQUENTLY. Oil after every haircut always. Also, if there is not enough tension on the blades, the hair will slip between the blade and blade guard, getting caught and damaging the blades. Blades should be screwed on tight. Also, it may be time to replace the blade if nothing else helps. These blades do not last very long in my experience especially if not carefully cleaned and oiled.
Posted on Jun 09, 2010
    Problem Solver:
  • 9 Answers
YOU MIGHT NEED TO CLEAN THE HAIR OUT OF THE CLIPPERS. AND OIL IT
Posted on Jun 06, 2009
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Using T-84 Andis blade for horses and cutting
Check the two screws either side of the hinge assembly make sure they are tight, the problem appears to be with the clipper if all blades do the same.
Jan 16, 2010 | Oster Golden A5 2-Speed Universal Motor...
I just had my A5 clippers serviced and was
Do you know how to sharpen your blades? Sounds like you need to give them a quick touch up.
Sep 08, 2009 | Oster Golden A5 1-Speed Universal Motor...
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
Can get it right
Jun 11, 2009 | Oster Golden A5 2-Speed Universal Motor...
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Blade won't cut
Try replacing the Drive Lever which is located at the end of the clipper and goes from side to side, simply undo the two screws on the name plate/ gearbox cover and remove then pull the lever out. This is the most likely cause if you experiance the same problem with all blades.
Dec 26, 2008 | Oster Golden A5 1-Speed Universal Motor...
Health & Beauty Logo
1,294 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
