Question about Canon MP520 All-In-One InkJet Photo Printer
Canon MP520 can print but not scan
When trying to scan, there is an error saying that the scanner is not attached. Yet I can print on the same device without problems. I have downloades and installed the latest MP520 canon all-in-one driver for Max OS X 10.4 twice, but this changes nothing.
  • Thom DelForge
    Thom DelForge Apr 19, 2009
    Same issue -- my MP520 works fine except for the scan mode -- all things are go -- after pressing 'start' -- nothing.  I am running OS X 10.4 on my G4 Mac.
  • JanPenny Apr 21, 2009
    I have the same issue - It worked when I had it connected to a PC, but now I have a Mac. I have installed the drivers for OSX, and it does print and copy, but it still won't scan. Very frustrating!
I had the same problem. The all-in-one driver download doesn't include the stuff you need for the scanner. Go to this link (canon), click "OSX" on the dropdown list for what os you're using, then click "mp520sosxsd1391ej7.dmg" under "MP520 series Scanner Driver Ver. 13.9.1 (Mac OS X 10.2/10.3/10.4/10.5/10.6)." It doesn't take long to download and completely fixes the problem.
Posted on Sep 11, 2009
  • marubrittle Sep 05, 2010
    thank you.. Beautiful. My scanner is working now!
  • the_tia
    the_tia Feb 05, 2014
    I also found out that 10.9 doesn't need a patch. I just went to my system preferences, found printer and scanners, selected scanners and a utility window pops up and I was able to scan like this too. YAY! Thanks for your guidance. It still helped get me to the right place on the canon website.
My canon mp520 wont scan
Posted on Jun 09, 2009
    New Friend:
    Problem Solver:
  • 5 Answers
Paper Jam occurring regularly in main unit. what to do.
Posted on Dec 01, 2013
Printer says I have an incorrect head, but I never changed it.
First try doing this: Manual Resetting Method for Canon Pixma MP520
The manual for your printer is located here: http://gdlp01.c-wss.com/gds/1/0300000381/01/mp520_qsg_us_v1.pdf
The troubleshooting for your message (p72) says to remove and replace the print head. If that does not fix it is says the print head is likely damaged and to contact canon support.
Oct 05, 2014 | Canon PIXMA MP520 InkJet Printer
My canon pixma mp 250 will not scan code error shown 2,140,2. find the answer my email id
This could be because the ink cartridges may be empty or been replaced with compatible types.
Solution:
You could try to do a reset by pressing and holding the reset button (red triangle) for 5 seconds. If that does not clear the error then try pressing and holding both reset and maintenance (pliers and screwdriver picture) for over 5 seconds. The flashing error code should change to normal counting display digit 1, and the scanner become usable.
Sep 21, 2011 | Canon PIXMA MP520 InkJet Printer
Doesn´t scan or print; error
The 5100 error on this printer can be caused by a bad/faulty Carriage Unit, or Timing **** Film, or Logic Board, or Carriage Motor. If your printer is blinking only 2 times then a pause then blinks again 2 times this is more then likely the issue. You will need to contact Canon and find a repair center near you to fix this issue.
1-800-828-4040
or
1-800-652-2666
Best of luck..
Have a Happy and Safe Holiday Season...
Dec 01, 2010 | Canon MP520 All-In-One InkJet Photo...
Scanner will not scan an item into My Documents
try to uninstall then reinstall the driver. to do that go type device manager in run box in XP and start search in Vista/ Win 7, and look for the scanner. right click and uninstall. then load the driver from the website or from the cd that came with your device..
Mar 29, 2010 | Computers & Internet
Mp520 will not scan, document is on glass platen, press the black and white scan button but nothing happens. please hel. thanks
Did it come with any software? My printer wouldn't print when I tried using the scan button. If it came with software you could try scanning using that. If you dont have it it's probably available for download on canon's website
Sep 22, 2009 | Canon MP520 All-In-One InkJet Photo...
Exact same problem as OP
Canon support was able to help me with this issue.
First, scanning with the MF Toolbox is only supported via USB, not across the network (scanning across the network generally does work but you need another application that supports it). Second, you must make sure that you have switched the device into USB scan mode. Press the Scan button on the device. If the display says "Network scanning" press it again until it says USB Scanning. From then on, scanning works beautifully.
Aug 22, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
I have a Canon printer (MP520) and I am trying to scan a document. It gets me to the point where it tells me to press a button (a black diamond) to begin and nothing happens, no movement. It photocopies...
check if your scanner add on software was installed into your PC like InfraView or other scanning software.
also check the connection from the unit into your pc.
Nov 05, 2008 | Computers & Internet
Canon MP520 Scanner / printer
This is down to a hardware error in the tank itself. Only remedy is to replace the ink tank and not use refilled or copy tanks.
Sep 30, 2008 | Canon MP520 All-In-One InkJet Photo...
Pixma mp520 scanner won't scan
I emailed Canon Tech Support (after searching their MP FAQ) and received this response. It worked for me:
Please follow these steps to set the push button event for the MP520
scanner:
1. Click on the Windows button and then Control Panel.
2. Double-click 'Scanners and Cameras'. For Vista users, if 'Scanners and Cameras' is not listed, click 'Switch to Classic View' on the left and then try again.
3. Double-click on the MP520.
4. Next, click on the Events tab.
5. For the 'Send to this application' option, select ScanGear driver, MP Navigator, or imaging application you would like to use for the scan button event in the list.
6. Click Apply or OK to save your settings.
Jul 16, 2008 | HP PSC 2110 All-In-One InkJet Printer
Problem with CanoScan Lide 500F
I would reinstall the driver first. Get the latest ScanGear and Toolbox from the Canon Website.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=11011
Do you have any other image devices such as a Multifunction (scanner,fax, printer) or digital camera attached to the computer?
Jun 30, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
Canon MP520 All-In-One InkJet Photo Printer Logo
7,394 people viewed this question
old marine
old marine
