Doesnt seem to be broken but cant seem to figure out how to get it back on.
SOURCE: How to remove upper spray arm of Maytag DWU 9200 BBE dishwasher
There is a plastic clip that holds the spray arm to the inlet line. This clip is in the center and has to be sqeazed together to release the arm.
Both upper and lower spray arms become clogged by different objects like paper, plastic, stems from fruits, etc... These are particles that cannot br dissolved be the detergents.
SOURCE: broken nozzle and upper spray arm
the spray arm just screws back on, unless of course its cracked in which case needs replacing( chances are since it fell off its cracked) heres the part num 154478202
SOURCE: The upper spray arm came off. How to I put it back on?
I realize this problem was in March of 2008 but if in the case someone else needs the solution. The Frigidaire website doesn't list this in there troubleshooting list either.
I had the same problem and let the upper spray arm off for a couple of months. My glasses were not getting cleaned as well so I was rewashing everything by hand. What's the point of that if I have a dishwasher.
On the inner roof of the dishwasher there is a round piece that you hook the upper spray arm to. Well it's a pain to try to just snap it on. Unscrew it by hand, get the little white plastic piece so the teeth are pointing out of the hole and snap on it on that way. One tooth at a time and it should go back on. It will be wobbly. Works like new I am so happy !
From now on be careful what you place on the top rack, if the item is too big it will cause it to snap off again. I know I will :)
Thank god I didn't get a repair man in here for something as minimal as that.
SOURCE: bosch SGS43E08GB/45 DISHWASHER
Simply the bearings on the main wash motor need to be replaced. Hardest part is to remove motor from unit. Assuming you have available tools including a medium sized bearing puller you could D.I.Y. bearings can be bought at your local auto spares shop.
SOURCE: Lower spray arm does not spin on my bosch dishwasher
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
