Question about Mitsubishi WD-52525 52" Rear Projection HDTV
3-5 error code on mitsu wd-52725(chassis fan failure)
One last try, can anyone offer any insight as to the root of this problem,such as what capacitors i should check. the fan test good.
  • miridgew Mar 16, 2009
    Thank you Slinteriors. some of the fuses on the board are VERY tiny I don't think I could attempt to test or change them, but I'll check it out along with the list of capacitors. Can you tell me how to actually test a capacitor other than visually... a meter?..
  • Mitsubishi Master
  • 8,617 Answers
Check the power PWB pico fuse F9A09 and if thats good check the following capacitors all on the power pwb.
Power Supply
C9A52 1000uF 16V
C9A59 1000uF 16V
C9A61 1000uF 16V
C9A62 1000uF 16V
C9A39 2200uF 35V only some versions
have this cap.
C9A40 2200uF 35V
C9A37 3300uF 16V
C9A38 3300uF 16V
Posted on Mar 15, 2009
  • Sonny Berry
    Sonny Berry Mar 17, 2009
    You would need a ESR meter to check the capacitors, often they wont show any outward sign of being bad, they are very inexspensive I would change the ones indicated. Just test the fuse with a ohms meter for resistance.
Hello my name is Devin, I have a wd-65735 model and I just purchased it off of a friend and braught it home. He had told us from laying it on its side while bringing it home it said in the guide to let it...
Caveat: I am not a tech, I just read through the Mitsubishi service manual, and have worked on different model TV that I have owned (older model of this one) I am a little unclear on the second set of lights but I think the combination *may* indicate that the lamp fan is not starting (there are two fans though), if the blinking red is the status light. It is possible the connector for that got jostled during the trip, something fell into it from being on the side (wire or loose something) and is blocking it from spinning now, or a module unseated a bit,and is loose, or the lamp is no longer seated correctly (though the lamp light does not appear to be on) or none of these. :) These are just guesses.
Be careful if you open it up, due to potential for shock. Wear gloves, and power it down first (then unplug). Reseat any fan connectors.
Google: I used "wd-65735 status lights" to find a service pdf , it's for V39 chassis (several models)
From page 24 of Service Manual :
3. Error Code Operational Check Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Opera- tional Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The "TIMER LED" flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
  • ThenumberofflashesindicatesthevalueoftheMSD(tensdigit)oftheErrorCode.
  • Theflashingthenpausesforapproximately1/2second.
  • TheLEDthenflashesindicatingthevalueoftheLSD(onesdigit)oftheErrorCode.
  • The Error Code is repeated a total of 5 times. Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
Page 24
MODELS: WD-60735 / WD-60C8 / WD-65735 / WD-65736 / WD-65835 / WD-65C8 / WD-73735 / WD-73736 / WD-73835 / WD-73C8
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
ERROR CODES page25image3968
Code
Description
Most Likely Cause
12
No Error found
17
Communication loss, TV Micro - Engine (3.3V-ENG-SDA & SCL)
Engine Failure
18
Engine will not accept data (ASIC-READY signal from Engine is not detected).
Loss of 12V from PWB-POWER (Loose PE or PE2 connector); Bad Color Wheel (Loose J6 or J7 connector); Engine Failure
32
Lamp cover is open.
Lamp Cover Switch; Loose CD connector
34
Lamp turns Off while the TV is playing. Lamp failure
(Lamp Enable signal from engine is lost)
Lamp Cartridge Failure
36
Exhaust Fan failed.
Loose J4 connector
37
Engine (DMD) fan failed.
Loose J5 connector
38
Lamp temperature abnormally high.
Poor Air Circulation; Loose J3 connector
39
DMD temperature abnormally high.
41
Standby Supply Short is detected. (5VS or 3.3VS)
PWB-MAIN Failure
42
Sirocco fan failed (Lamp fan).
Loose J8 connector
44
Check for disconnected DVI cable between PWB-DM and Engine. (Engine pulls DVI pin 14 Low)
DVI Cable unplugged
48
PON-SHORT 3.3V switched supply short
PWB-MAIN Failure
57
Ballast communication problem (ballast to chassis)
Loss of 340V from PWB-POWER (PL or CJ1 connector); Loose FB or CJ3 connector; Ballast Failure
61
No LAMP-EN output from the engine to the ballast
66
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp) (Lamp-Enable goes to DM but not to Ballast)
Loose CJ4 connector;
No Lamp Inserted;
HV connection or lead wire to lamp; Lamp Cartridge Failure
Code 34(1) - Lamp Enable is generated to activate the Lamp
Code 57(2) - Lamp Enable is generated during P-ON sequence, but no Lamplit signal is received from the Ballast. Code61(3) -NoLampEnableisreceivedattheDMandBallast.
Code 66 (4) - Lamp enable is received at the DM but not at the Ballast.
4. Error Code Log
The Error Code Log - may be helpful to retrieve the code for an error the occurred in the past. To access the Error Code Log: Press <MENU> <3-5-6-4>
Oct 27, 2014 | Televison & Video
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Error Code 56 and Yellow Status Light
check the error blink code again as 56 is not a valid error code for the WD62525
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Jan 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD 52525 lamp replaced, no picture, red light
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
Jan 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Error code 1 2
I found this list of codes
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Bad light engine
Did you replace the bulb? Your supose to replace the bulb when you do the ballast but a lot of techs do not.
Jan 09, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
339 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
