Washer won't turn on
My washer quit in the middle of a cycle and won't turn back on. I have the stackable kind. Dryer on top turns on but not the washer
  • 10,865 Answers
Begin by checking to be sure the outlet where you have the washer plugged in has power. you may have blown a fuse or popped a circuit breaker. If no power, either replace the fuse or reset the circuit breaker by turning it all the way off and then all the way on.
Posted on Feb 28, 2009
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
