Question about Sharp 64LHP5000 64" Rear Projection Television
My Sharp 64LHP5000 TV quit working just blinking red light on front. This model has allot of protection built into the circuitry which might help diagnose the problem. The D1132 LED is lit on the E amp Convergence / V. def board. Any idea or common problem that your experience might me able to help repair this problem? Thanks, Alan
    President:
  • Sharp Master
  • 1,779 Answers
There's no case history on that chassis, however, the common problem with projections sets are the large convergence ic's (2). If I had the svc manual we could isolate the problem more closely. I did check my suppliers and the boards are still on the market, the deflection module sells for around $500.00, I suggest go component level trouble shooting, allot cheaper. If your not up to that then I recommend calling a local svc co.
Posted on Feb 28, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Tv wont turn on, just red light blinks
From the owner's manual of that model:
If a red light is blinking on the front of the TV, the set has entered protection mode. If this happens it usually means you simplyneed to reset the TV. Unplug the TV for 60 seconds. Then plug the TV in and try to switch it on. If the light is still blinking red,call the Customer Care Center at 1-800-531-0039
Dec 08, 2011 | Philips 55PL9524 55" Rear Projection...
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a Sony Grand Wega rear projection TV model KDF-42WE655 and suddenly have no piucture and red light on front is blinking.
Hi.
blinking of standby light shows that your television has entered its protection mode. There may be some fault on its circuitry. Its is often called as self diagnosis indicator. Please count the number of blinks for us to help or guide you on what to do.
Dec 06, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Sharp 56DR650 LED Blinking
Check the number of time it blinks. that is the error code and compare it with the problem listed in the owners manual. see www.fixurtvs.com. The code 32 means the color wheeel is getting stuck. You can try to clean it and put it back or look for a replacement. Repairs should cost you 350 to 450 at shop and 150-250 at home subject to the availability of parts. Cleaning it just a stop gap measure and not a lasting solution. dont worry if the wheel opens up into two with black dust inside. Just clean it put a drop of light machine oil like sewing machine and put it back. there will be hum but the wheel works for months and maybe a year. it varies from tv to tv and quality of your workmanship.
Jan 24, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Sharp Aquos 32GA5U red blinking light in front but no picture!!!
Right now your TV is in " Protection Mode " because of a failed part inside. The blinking red light is a error trouble code. Only someone with the actual Service Manual for the TV will know what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common board to go bad is the Backlight Inverter Board. It what supplies power to the screen. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 19, 2009 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
Red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Jul 24, 2008 | Philips 37PF9631D 37 in. LCD HDTV
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Sharp 64LHP5000 64" Rear Projection Television Logo
236 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
