I have a 50" Scenium HDTV. A DVD player and a Sony Playstation have been plugged into the TV and have been working fine for 2 years. All of a sudden, they now play for 5 seconds and stop. What has happened? We have unplugged both devices and plugged them back in, but this does not make a difference. I really need these to work. Can't watch DVDs and my son can't use his playstation.
  • 121 Answers
The first thing to check is the ventilation in the back of the set.
Posted on Feb 28, 2009
My GE universal remote for RCA Scenium tv doesn't work the DVD part
If this is a combo unit (TV with DVD built in) you need the original remote---Universals almost always are missing key features the original remote had as most companies have someone else make the unit and put their name on it.
Mar 21, 2012 | RCA Scenium D40W20 40" Rear Projection...
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Hooking ps3 to toob tv not hd
its siomple if before you us to conneted to an hdtv just hold the turn off button on the ps3 for about 10 seconds to restart the settins. but if is the first time you connect your ps3 to a tv just plug in the a/v cable (red, white, and yellow) to the tv.
Apr 27, 2008 | Sony Playstation 3 (PS3) Console
Connecting a wii to a RCA Scenium
Sorry but I have to ask, are you sure the cables were plugged in correctly on the bigger set? Try using your tv's input button to scroll through the different inputs until you come to the one where the Wii is plugged in. You can check which one by looking where you plug the cables in. i.e. line 1, line 2, component 1, etc. Hope this helps.
Mar 15, 2008 | Televison & Video
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Integrated DVD player
If your handy, then try to disassemble the DVD .player from the unit and manualy clean the lens assy,but please be aware of the HI Voltage dangers inside of a tV set. if your not then Please call a pro top assist you with this repair. If the units not worth fixing then simply buy and inexpensive DVD player/recorder and hook it up via the external inputs. Good Luck
Jul 24, 2006 | RCA Scenium D40W20 40" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
