Question about Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57 in. won't turn on
When I connect the tv to the wall outlet the power red light start to blink 6 times continuosly and if you press the power button it start to blink 8 times continuosly. please any help with this?
  • kevin272 Mar 15, 2009
    I turn on my tv and it stays on for 2-3 seconds. It then turns off and the red light on the front of the tv blinks 8 times. Can anyone help me?
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
ladywinn
  • 5138 Answers
SOURCE: Sony KP-57WS510 57 in. Rear..
you most likely have bad STKs 392-110s or120s this will cause your problem!
Posted on Jan 19, 2008
SOURCE: Sony KP-46WT510 wont turn on
Can you tell from looking at the HVB that its bad?
Burn marks on them ect...
Mine looks like nothing is wrong with it.
Posted on Apr 27, 2008
SOURCE: Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Posted on Oct 19, 2008
SOURCE: Sony Wide Screen Projection TV KP-51WS520
I had the same problem. blinking 9 times, pausing, 9 times...... remote would not power the tv on. after five minutes of pressing the remote it finally would. after turning it off you would have the same problem. sometimes a half hour of pressing remote in every which what way. finally left the tv on for three days and would mute at nite to go to bed. didn't think that was the best way so turned it off and it never turned back on. checked all the forums and found out it was the g board. unfortunately, you cant buy the whole g board anymore. if you take the back panel off the tv, on the lower left corner is where the g-board is. there are 3 little things to unplug and two screws (phillips head) in the middle of the g board. its simple to figure how to take it out. go to the sony direct parts website. the part # is A1054157A for the g board. since they dont sell it anymore they have a phase 3 program where you send in your old g board and they repair it for 64.95. it'll cost about 8 bucks to ship it to them. better than the 400 bucks the tv guy wanted. address is sony customer satisfaction ctr. , materials door 27H, mount pleasant, PA 15666 there number is 866-748-8272. call first and they give you the step by step instructions what to do. after tax and shipping it came out to less than 80 dollars.even came with a warranty. got it back in a week, popped it in and just love turning the tv on. anyone can do it.
Posted on Feb 06, 2009
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
I'm working on my 1996 model KP-53v35 Sony. The problem is that I plug it in and it tries to come on and the red LED flashes and it shuts off.
If the lamp light is blinking, then lamp needs to be replaced. If the standby light is blinking, the try resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the service may be required.
Jul 26, 2010 | Sony KP-53V35 53" Rear Projection...
MY SONY PROJECTION TV WEGA KP-FX432 BLINKS 10 TIMES THEN TURN OFF.PLEASE HELP ME
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 22, 2010 | Sony KP-FX532M91 TV
It will no longer turn on... the standby/timer light blinks 6 times and then NOTHING... what's wrong with it??? and how can it be fixed or can it be fixed at all
Jul 22, 2010 | Sony KP-43HT20 43" Rear Projection...
I have a Sony Kp-51ws520 5 blinks
Jul 22, 2010 | Sony KP-51WS520 51" Rear Projection...
My tv blinks 6 times no picture
Jul 19, 2010 | Sony KP-53HS30 53" Rear Projection...
Sony KP-57WS510 red light blinking 5x
Jul 19, 2010 | Sony Televison & Video
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
135 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
