Question about Asrock GE PRO-M2 Motherboard
Asrock ge-pro-m2 does not boot
Just what the title says. the computer does not boot windows/cds.
it does POST but after that i get to a screen saying amibios configuration i get the system specs. and the blinking line at the bottom of the page. i cant seem to go farther then that. what exactly should i do?
oh and btw the windows already installed on the system gave an error saying its missing a file i dont really care for that because im formating it and installing a new copy but now it doesnt get to the point of telling me windows is missing a file and cannot boot its just stuck on the amibios configuraion it is not the bios setup menu.. and the keyboard seems to not respond. thx
  • 2 more comments
  • malky_david Feb 28, 2009
    i did try that. it did not work. i tried unpluging everything! was down to the MOBO alone with no PCI devices. just MOBO PSU and the pwr switch did not works.
    thx a lot. yesterday i did clean the computer. every inch of it [i dismembered it and rebuilt it]. i guess the RAM wasnt properly sitting on the dimm. i took it out and it worked. put it back in. and it still works. but just to be sure ill give it a nice GOLD MEMORY run over night. thanks again you helped alot
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try unseating and reseating the memory and CPU and make sure if you have more then one stick of memory keep trying just each one in each different slot each time you boot up to verify whether it might be a memory problem or a memory slot problem and make sure everything is free of dust by using a can of air to blow it away.
  • Ben Wabnick
    Have you tried the hard drive. Try unhooking the hard drive completely from the system then turn it on and see if it goes further. Hard drive might be going bad on you.
  • 2,404 Answers
Rate me for the solution I gave you about reseating the memory please. Have a great day.
Posted on Feb 28, 2009
Boot by USB drive
The most likely problem is that some of the information is missing. is the Bios file on the Stick and is it un-compressed? you also need to ensure that the Bios flashing software is on the stick. But, for better info, go to the website where you downloaded the BIOS file and read the instructions there. They always give instructions for BIOS flashing. (well I haven't found one that doesn't yet)
Jan 28, 2012 | Asrock GE PRO-M2 Motherboard
Asrock ge pro-m2 whats the best spec i can upgrade to?
According to the downloadable manual on the manufacturer's web-site:
http://www.asrock.com/MB/manual.asp?Model=GE%20PRO-M2
the maximum RAM supported is 2GB, and it is a Socket 478 CPU interface.
Since you don't have the "GE PRO-HT" motherboard,
you cannot use a "hyper-threading" CPU.
So, you can use any non-hyper-threading Pentium/Celeron that has a Socket 478 interface.
Dec 08, 2009 | Asrock GE PRO-M2 Motherboard
No connect enternet
try this link it should have all the drivers you need
http://www.lostmydrivers.com/bios-and-system-update-drivers/asrock/page_5.html
Feb 11, 2009 | Asrock GE PRO-M2 Motherboard
Drivers sound
Hi gallardolagu,
You can download the sound drivers for your motherboard at the following location:
http://www.asrock.com/mb/download.asp?Model=GE%20PRO-M2
Hope that helps,
Take care,
Michael
Nov 19, 2008 | Asrock GE PRO-M2 Motherboard
No Post
I always suggest this and many times I get yelled at, but I'm just trying to help...
Did you plug in both power cords? There are two, one is rectangular and one is a smaller square shaped connector.
If that's not it and you've tried pulling all the cards and devices (RAM, HDD, CD/DVD) then you most likely have a bad motherboard.
Good luck.
Dec 28, 2007 | Asrock GE PRO-M2 Motherboard
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Screen not showing anything
Some time the system will work due to insufficient power source this problem may occur replace SMPS and check the CPU heat by touching it. If it warm then the CPU is functioning. Else contact your nearest hardware vendor.
Hope this will solve your problem.
Nov 22, 2007 | Asrock GE PRO-M2 Motherboard
Asrock GE PRO-M2 Motherboard Logo
428 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
