Question about Mitsubishi VS-60607 TV
I need a schematic for a mitssubishi VS-60607 convergence circuit
Schematic
Send me yr email and I can send ya a schematic I have.
larry@riotgun.com
Posted on Apr 27, 2009
VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Mar 13, 2012 | Mitsubishi VS-60607 TV
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: captainhawk1_15.jpg
May 29, 2011 | Mitsubishi VS-60607 TV
Mitisubishi 60607 will come on the go right back off
you have a component failure. begin checking the on-board fuses. that should lead you to the circuit that failed. most often it is the convergence circuit. 2nd most is a loss of vertical deflection. this is a tube protection circuit that shuts the set off before it destroys the crt's.
Jan 06, 2010 | Mitsubishi VS-60607 TV
Tv turns on. There is a picture but it looks like your looking through a fish bowl. Bowes into the middle from both sides. It also looks 3D. Any Clue??
This is usually a convergence problem, although the bowing normally is from the top and bottom rather than from the sides. There may also be an issue with the pioncushion circuit that causes the bowing. Try the automatic convergence adjustment first. If that fails to resolve the problem, then resoldering the convergence ICs would be next followed by replacing the ICs should the resoldering fail.
If you wish to attempt the repair, please update this and confirm the model number to be VS-60607 and I'll provide additional details.
Thanks,
Dan
Dec 08, 2009 | Mitsubishi VS-60607 TV
I have a Mitsubishi VS-60607 Tv and it started out
Without going in with troubleshooting equipment it is hard to determine if the problems are related or not but it is unlikely since you seem to have a video problem and a convergence problem , which are two separate circuit(signal processing and deflection). Hope this help.
Please do not rate this answer(unless it helps)as it is only a suggestion.
Dec 03, 2009 | Mitsubishi VS-60607 TV
How can i get a schematic for the mitsubishi vs-60607 convergence circuit
U don't,the corporation does not allow it.U can get the convergence kit,comon prob.for all DLP tv.U know how to solders right?try this website for the convergence kit,use what in that kit,should solve ur convergence prob.
Oct 20, 2009 | Mitsubishi VS-60607 TV
When i on the t.v it looks double and then off.VS 60607
Ur convergence is dead,U know how to solders?Buy a convergence kit,replaced what in that kit.Ur tv will be back to normal.This Website have that kit.Tv repair World.com.
Oct 15, 2009 | Mitsubishi VS-60607 TV
My picture is wavy, I have a mitubishi big screen model # vs-60607
sounds almost like bad caps okay this is where i would start is thier an option on the set to alighn convergence try that also okay may be bad module also okay its worth fixxing okay call tv shop
May 17, 2009 | Mitsubishi VS-60607 TV
Need help
If you have no TV repair experience, or any experience tracing circuit flow with a schematic, call in a tech to assist you with this repair. This tv set is not the place to be experiementing inside of. You probably have bad capacitors in the power supply or the sweep power supply. Good Luck
Sep 30, 2007 | Mitsubishi VS-60607 TV
Picture goes out after a few hours.
coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop if you may have more question , let me know Im here to help you. thanks
Jun 12, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
240 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
