Question about Bosch Axxis WTA 3510 Electric Dryer
Dryer doesn't power-on.
I have a Bosch Axxis WTA 3510 Electric Vented Dryer. When I press the On switch, it doesn't come on - all the lights stay off. I'm sure I have power because my Bosch washer, which gets its power from a 220V port on the dryer, works fine. What could this be? Thanks!
    Habit-Forming:
  • 158 Answers
Simple answer: way too much dryer lint. Worth cleaning out.
Posted on Mar 04, 2018
SOURCE:
textonor
  • 130 Answers
SOURCE: Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Posted on Jan 06, 2008
maklean
  • 1665 Answers
SOURCE: Service Manual
http://www.servicetechhelp.com/index.php/downloads/6124
Posted on Jun 26, 2008
  • 1531 Answers
SOURCE: Bosch Axxis WTA 3510 Electric Dryer. I changed the
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Posted on Sep 16, 2009
  • 10865 Answers
SOURCE: Bosch Axxis electric vented dryer
Hello. Begin by checking the clothes carefully as you remove them from the washer as it could be that the washer, and not the dryer is making the holes. That said, try drying smaller loads at a time. Sometimes, this is all it takes to be trouble free.
J.
Posted on Sep 04, 2010
  • 351 Answers
SOURCE: Bosch AXXIS dryer # WTA 3510 uc slipping /
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Posted on Sep 30, 2010
Testimonial: "Will try it with help of a friend. Sounds much less expensive than replacing motor as Bosch dealer suggested. Thanks"
When The door is open continues to run on my Bosch Axxis Clithes Dryer WTA3510US
the door switch contacts are welded together,normally it switches when the door is opened to light the interior drumm light and to the dryer circuit when the door is closed,but these contacts cant due to being stuck
Nov 15, 2012 | Bosch Axxis WTA 3510 Electric Dryer
What does E1 mean?
Welcome to FixYa.
Can you possibly double check that model number and reply post. I ask because the "E1" error should only pertain to those models which are condensor (non-vented)... "WTL" dryers.
The error indicates either a blocked drain hose or a failed pump. This from Bosch...
E1 Pump failed
(WTL 5400condensationdryer only) Pump failed.
Check voltage at and wiring to pump.
Turn off dryer, measure pump resistance (110 - 136 ?) and replace faulty pump.
Also - Following items apply only to the WTL (Condensation Electric Dryer) models
Cycle is interrupted and ''E1'' appears in display• Condensate hose is blocked in some way. Turn off dryer and check hose.
I'll watch for your reply and try and help you move forward in any manner I can.
Regards,
Macmarkus :)
Apr 14, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Dryer wont start
1 INSPECT POWER SUPLY
2 DOOR SWITCH FOULTY
Feb 27, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Service Manual
Based likewise on your Premium Problem/Post here, I tried looking for a service manual but only found a possible source of the wiring diagram, have you tried here. Unfortunately, you need to be a paid member to access the files to my understanding.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 25, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
114 people viewed this question
Top Bosch Dryers Experts
Elie Balas
Tommmix
Level 1 Expert
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
