Question about Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens
FEE message in display when using 50mm lense
Hi - i have a new Nikon 50mm 1.8 lens for my nikon D70. sometimes when i use this lense it freezes the camera and a message reads in the top right hand corner of my display "FEE". do you know what this means? also, any other of my lenses work normally!
    Scholar:
  • 48 Answers
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Posted on Mar 02, 2009
  • 1 more comment
  • campbells160
    campbells160 Oct 15, 2012
    Does this mean that f/22 is the only aperature setting that is usable with this camera/ lens combo?
  • campbells160
    Does this mean that f/22 is the only aperature setting that will work?
  • Brian Williams Oct 16, 2012
    All aperture values are available to the camera, f/1.8 - f/22, but with a camera like the D70 the apeture ring ust be set at f/22. If you want to choose the aperture for shooting, you set the camera exposure mode to A and choose the aperture with the command dial.
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
I have a D70 and have just received a 50mm NIKKOR AF 1.8 primary lens. when I fit the lens, I get a flashing FEE message and the camera deos not work. Can you help?
Turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it. Control the aperture from the camera, just as with other lenses.
Nov 12, 2010 | Nikon D70 Digital Camera with 18-50mm Lens
LOOKING FOR A Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens WITH VR.
There is no such thing. You can see a full list of current Nikon lenses at
http://www.nikonusa.com/Find-Your-Nikon/Camera-Lenses/index.page
You can see a list of current and old Nikon autofocus lenses at
http://www.bythom.com/nikkordb.htm
You'll see that no 50mm Nikon lens has ever had VR.
Sep 28, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
When mounting either of my Sigma 70-300mmD lens on my Nikon D200 I get the fEE symbol. I've locked the lens at f22 with no results. It's worked flawlessly for me for years. Both lenses work beautifully on...
Have a close look at the iris ring to see if any think is broking off
or try moving the lens when it is locked on the camera to see if you lose the fee if so it may need a new mount
Aug 17, 2010 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
I can get my 50mm lens to work with my d70 nikon.
If the lens has an aperture ring, make sure it is set on the largest f number. Make sure the lens is mounted fully on camera. Oherwise an AF 50mmm f1.8 lens should work on a D70 with no problem
Oct 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
Mar 09, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
FEE display contant
defective focus lens circuitry, you need pro fix.
Sep 14, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Crash
The D70 has a reset button at the bottom of the camera. Firts of all, I think you have checked you have the correct lens inserted (at least D mount) and well done, checked your memory card is correctly inserted, and if you have another, change it.Checked the battery. Looked the AF modes on the body. If everything is OK, then press the reset button. If you have no answer, then take the camera to the T. Service.
Sep 19, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
What does the fEE error message displayed on an SLR camera mean?
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again. The fEE error message Set to f22, or the highest aperture number - normally marked in orange. Note the locking switch.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens Logo
552 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
