Question about JVC AV-60D501 60" Rear Projection Television
TV SHUTS OFF AFTER A FEW MINUTES
AFTER THE TV IS ON FOR A SHORT WHILE IT WILL TURN OFF BY ITS SELF. WHEN YOU TURN IT BACK ON IT WILL TURN OFF AGAIN. THE TV IS A JVC AV-60D501
  • des_sdd Mar 11, 2009
    IT IS NOT A HEAT PROBLEM IT SHUTS OUT BEFORE IT CAN HEAT UP
  • 121 Answers
Very likely to be a heat issue, the first thing to do would be to clean the ventilation slots in the back.
Posted on Feb 28, 2009
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
After 2 or 3 minutes tv turns off it self
CK capacitors 114,120,150 if any of them is puffed up on top it is bad so replace all 3 capacitors cp150 2200uf 16v other 2 are 220uf 35v resolder all pinns on FBT flyback Transfomer.
Feb 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
Tv won't turn on..
need to replace the power supply
Sep 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
RCA will not turn on
replace the flyback. you can get a replacement at the following link with free tech support to expain step by step how to replace it. you need flyback 259296 Heres the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | RCA D61W20 61" Rear Projection Television
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung HCM4215W,shuts off.
Sounds like a short in the power wire, it takes about 10 to 15 minutes to warm up then shorts out and when it cools down you can watch for 10 to 15 more minutes before it shuts off again, you need to take it in and have the powercord replaced because this is very hard to do from home and one mistake can make the whole tv not work.
Feb 27, 2008 | Samsung HCM4215W 42" Rear Projection...
Tv keeps turning off
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
Feb 05, 2007 | Panasonic PT-45LC12 45" Rear Projection...
JVC AV-60D501 60" Rear Projection Television Logo
324 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
