Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Unable to reassemble dyson animal vacuum
Vacuum had noise with brush on, disassembled plate at beater bar, clean out debris, that noise now gone, now there is a whistle noise like something stuck, removed rear lower hard plastic tube (one twist screw) and am unable to reasseble correctly, now catching on lowering mechanism at right rear.
SOURCE: Dyson Animal clogged
Here is the best way to clean your dyson that I have found!
Posted on Mar 02, 2008
Agent Don
  • 310 Answers
SOURCE: dyson animal will not stand up and question concerning lifetime hepa filter
Dyson animal will not stand up and question...
Posted by madmimi on May 28, 2008
my dyson will not stand up by itself=catch seems to have failed and online instructions from dyson have not solved the problem- can anyone help
my second question is will dyson replace my lifetime hepa filter that is located beneath the debris collector, it is very black and is not washable
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your 1st question, you may want to check with a factory authorized vac dealer who does repair on the Dyson vacuums to see if they can correct the problem, or call the Dyson factory phone # listed below for the nearest vac dealer in your area. 2nd question. The Hepa filter is mostly a wear item and I was not aware of the lifetime Hepa filter and that also would be a good question for the factory to answer, I could not find an answer to the questions and they might be able to clarify the answer to both your questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Dyson Inc. 600 W. Chicago Suite 275 Chicago, Illinois 60610
Customer Service 1-866-693-9766 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 28, 2008
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Posted on Dec 23, 2008
SOURCE: Dyson Animal dc07 -- change belt
Read the manual -- available on the Dyson web site. Brushbar not spinning • Ensure brush control is set on carpets mode. Note: brushbar will only spin when the handle is reclined.
Posted on Dec 28, 2008
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
Happy New Year!
Posted on Jan 01, 2009
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ...
    • 1 MIN
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ...
    • 2 MIN
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Why does my Dyson Dc-39 vacuum have good suction, but the beater bar barley turns?
    The beater bar may be clogged with pet hair and other debris. You may have to do some disassembly to get everything working again.
    Dec 18, 2014 | Dyson DC39 Animal Canister Vacuum
    Beater bar
    It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
    Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Beater bar making a loud noise
    Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
    Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Beater bar not working. suction not working
    Check for a broken beater brush belt. Clean the beater brush, clear of all debris and add some WD40 at each end where the rubber holders are. Turn beater brush by hand to work the WD40 into the axle. Reassemble making sure the belt is on correctly. This should also help solve the suction problem as well.
    Oct 01, 2010 | Dyson DC07 All Floors Bagless Upright...
    Beater bar is slipping on belt on my Dyson DC17 animal
    Beater bar was turning intermittently. No noise. Removed bar, disassembled ends and removed lots of junk. Replaced, and works like new, so far.
    Mar 26, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Dyson vacuum DC17 beater bar won't turn
    sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
    Feb 26, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Hi the suction on my dyson hoover has gone very poor. I have cleaned all filters but suction is still pretty poor.Is there anything else i can do?
    your problem with Dyson is the reason why a lot of them end up in the trash. here is the link to an article that will help you locate the cat fur, or hair or other debris that is lurking inside your machine and causing you to loose suction
    Aug 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Beater bar belt needs replacedon a dyson DC14 animal
    Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
    Its in the instruction book
    Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
    114 people viewed this question
    Top Dyson Vacuums Experts
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
