Question about Zenith B27A11Z 27" TV
What station do i use to watch the dvd and do i push the up arrow?
  • 463 Answers
You don't use a channel. Make sure your DVD player is hooked up via the AV/Input on the back of the TV. Then, power up the DVD player and put a DVD in it.
On the TV's remote, press the "TV/VCR/SOURCE" Button until you see the DVD output onscreen.
If you do not have the remote control, you must navigate through the menus onscreen by pressing the "menu" button on the front of the TV and changing the input so you can see the DVD.
Take care,
Rob
Posted on Feb 28, 2009
  • Rob
    Rob Feb 28, 2009
    If you'd like, I'll email the owner's manual to you... leave me an email address...
  • shawtae clarkson Sep 23, 2012
    how do i change the imputs through the menu because i've done everything else
How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    WHATS THE HACKING CODE FOR MY JVC XV-N322 DVD PLAYER
    Try this link: http://www.videohelp.com/dvdhacks/jvc-xv-n322s/5424#30023
    1. When "REGION CODE ERROR" shows on screen after you've input your wrong-region DVD you push "ON SCREEN".
    2. When the DVD-menu is showing push "ON SCREEN" again and another DVD-menu will appear.
    3. Move the arrow over to the clock and press enter. The menu asks for "TIME" and you write 0:00:00 and push enter.
    4. You will now see the menu for the movie. Remove the DVD-menu by pushing "ON SCREEN" once. You can now watch the movie.
    (Tested and Worked!)
    Report this hack (requests/questions/spam/wrong/****).-->
    icon_minipost.gifRegion code hack posted by Alex2000, October 31 2009:
    Your hack is GREAT!
    Works fine on the JVC XV-N342 too.
    And right for JVC on the ESS chip:
    JVC XV-N320, XV-N322, XV-N330, XV-N332, XV-N340, XV-N342
    and so on.
    Thanks!
    Mar 05, 2010 | JVC XV-N322 DVD Player
    Samsung dvd vr357 Can not watch copied dvd on other dvd players
    I know with the Go-Video, the DVD disc has to be 'finalized' before it's compatible with other DVD players/computers.
    Check your 'set-up' menus while that disc is inserted into your Samsung DVD machine and see about pushing the 'up' arrow, if you have one, to see the contents of the DVD disc...then see if you can toggle to the right to see options for that disc, for instance, the title of it. You might see the 'finalize' option there.
    Feb 27, 2009 | GoVideo VR3845 DVD Recorder/VCR
    Remove a link from an armitron ladies watchband model 6P29
    More than 90% of Fossil's watches utilize pins that push out.  You can determine whether or not it pushes out by checking if there is an arrow on the back of the link.  If there is an arrow, you should push the link out in the direction of the arrow.  Usually, the link needs to be pushed at least 25% of the way out before it will be loose enough to pull out.  I suggest using pliers and be sure you pull straight out or you risk damaging the pin.  Be sure to watch for a small tube or 'sleeve' that may be in the link.
    Jan 20, 2009 | Fossil CH2331 Wrist Watch
    JVC XV-N212 DVD player - unlocking region code
    It is not a permanent hack, you will have to to it over for every movie you put in.
    Don't think theres a pernament one for this player yet but i'll try and post it on here if i ever find one. Sorry.
    Oct 15, 2008 | Televison & Video
    Changing the region code
    This unit is hard-wired to be the region for which it was sold;sorry...accordianman
    May 09, 2008 | JVC XV-N212 DVD Player
    Making my DVD Player Region Free
    It is not a permanent hack, you will have to to it over for every out of region movie you put in.
    Mar 30, 2008 | JVC XV-N212S DVD Player
    Recordes but dont play back
    before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
    push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
    scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
    Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
    Can i record from tv to dvd
    yes
    make sure the cables are connected correctly, the manual will show that.
    If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
    Feb 13, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
    Digital Audio moved from TV/SAT to DVD/LD
    Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
    Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
    Apr 09, 2007 | Pioneer VSX-D514 Receiver
    Zenith B27A11Z 27" TV Logo
    105 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
