Question about Kirby Ultimate G Bagged Upright Vacuum
Want to shampoo upholostery have a Diamond series can't figure out how to to it
  • Kirby Expert
  • 324 Answers
Instructions of upholstery shampoo HERE. Try if it will work well for you on an inconspicuous area before you do entire piece.
Good Luck
Posted on Feb 28, 2009
Can't figure out how to attach hose from plastic shampoo container to vacuum
The below link is to a Kirby site that provides a video for attaching the shampooer. Very informative.
http://www.kirby.com/Portals/0/videos.html
Jan 22, 2011 | Kirby Shampooer Shampoo Hose G3 Ultimate...
It wont turn on at all
There is a switch that prevents the motor from running unless the shampoo tank, (or bag assembly) is fully installed. Be sure the tank is tight against the side of the machine, and not blocked by the cord, The shampoo head must also be fully attached.
Jan 15, 2011 | Kirby Shampooer Shampoo Hose G3 Ultimate...
My shampooer only sprays a single stream of shampoo and water whenever I use it on the carpet... That and I can't get it to lay a nice even layer of shampoo to soak in and then pick it up...it always does...
You are probably missing the foam screen on the tank outlet. There should be a plastic disk with a fine screen in it on the tank outlet. If the screen is missing, foam will not be produced; and just soap water will be sprayed out. Sometimes the screen assembly can be found in the end of the shampooer hose.
Nov 01, 2010 | Kirby Shampooer Shampoo Hose G3 Ultimate...
I cant figure out how to **** up water with my kirby dimond
Vacuuming a wet carpet with your Kirby or any other vacuum not designed for wet pickup could do serious damage to your machine and there is a real danger of electrical shock to the operator.
Your Kirby Diamond and every other Kirby for that matter is NOT designed to pick up water!! Even with the shampoo system attached it will NOT pick up water or the shampoo foam. Your Kirby spreads the shampoo foam around on the carpet to clean it. You then only vacuum a shampooed carpet after it has completely dried.
May 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How does one use the shampoo system on the Kirby?
Greetings,
If you click the link below it will take you to a video demonstration that explains step by step what you need to do to convert your Kirby into a carpet shampooer. The vacuum in the video is the Kirby Sentria, but the procedure is the EXACT same as it is on your Kirby Diamond Edition, Kirby Generation 3, G4, G5, G6, etc. All Generation models have the same process of converting the vacuum into a carpet shampooer.
Instructional Video On How To Attach The Kirby Generation Series Carpet Shampoo Attachment:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this video was helpful to you. Please feel free to request a clarification if you have any further questions about the installation, I'm always more then happy to answer any question, seriously.
If you did find this video helpful, please kindly rate my soltuion as Helpful by clicking the Thumbs Up Icon at the the bottom right hand corner of this page.
Thanks for watching!
Chris
Mar 14, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Do not not how to use the shampoo cleaner on the kirby diamond edition /the ultimate g series
i ordered the manuel online for less than 10.00 and was there at my house in 2 days it was everything i needed..full of attatchement instructions.. i ordered from Kirby..
Jul 05, 2008 | Kirby Ultimate G Bagged Upright Vacuum
KIRBY SHAMPOOER shampoo TANK G3, ULTIMATE G DIAMOND
The bag assembly must be removed to attach the tank. Turn the fiberglass bag housing counterclockwise to remove, and replace it with the tank.
Dec 21, 2007 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
73 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
