Question about White Sewing 1766 Mechanical Sewing Machine
White 1760 skips stiches...
My white 1760 skips stiches...any solutions??
  • 69 Answers
Change your needle and use a ball point.
Posted on Mar 01, 2009
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Jan 12, 2013 | Sewing Machines
My stiches keep missing a stich
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
if these suggestions don't help the the machine could be out of
time & the machine would need to be taken to a sewing machine
shop to be checked
Aug 06, 2012 | Husqvarna Huskystar 215 Sewing Machine
Breaking uper thread & skipping stiches
Your problem may be the quality of thread or the type needle you are using ...
Jun 30, 2012 | Sewing Machines
Skipped stiches
Apr 30, 2012 | Husqvarna Viking 1
When I am sewing it will sew about 3 stiches and then jam.. It does it if I change weight of material or it will s kip stiches.
Skipped stitches is usually indication that needle is blunt or burred.
Or if you are using a sharp needle on knit fabrics it may also skip a little.
Not sure what you mean by "change weight of material" - do you mean you are sewing applique and going from one fabric weight onto another? or different sewing projects?
It is a good idea to change your needle for each new project (4-6 hours sewing time max) and choose the right type of needle and size for your project.
However, the jamming part sounds more like thread tension issues, especially if the jamming is happening underneath from the bobbin. If stitching is loose underneath, then top tension is the problem and visa versa.
Recheck your threading path, top and bottom tensions and that you have good quality thread. Change the needle, rewind a fresh bobbin, thread up and try again.
There is really good info on or I refer to my Singer Sewing Machine textbook at lot too. Good luck.
Mar 30, 2011 | White Sewing Sewing Machines
Tread breakage snd stich skipping
(A)Put in a new needle and rethread from the beginning. Make sure the take-up hook is threaded. Also, (B) clean lint out - sewing machines have very small margin for error when lint pushes everything out of alignment. Mostly, it sounds like your thread is stuck somewhere, which can even be at the spool, so (A).
Apr 06, 2010 | Juki DDL-8700
Hello I am new to the sewing hobby.My switches were fine during sewing a curtain then under & top stiches are a messed up. I rethread it might do fine 1/4 way down starts all over agian. Don't have a...
Here is a list of the model #s I found 1422 is not included are you shure about the #?
White 1077
White 1088
White 1099
White 1122
White 1202 1213
White 1240
White 1409
White 1411
White 1418
White 1466
White 1477 1488
White 1505 1510
White 1570 Classmate
White 1599 Jeans Machine
White 1600 Speedylock
White 1632
White 1700
White 1717
White 1760
White 1766
White 1787 1899
White 1800
White 1919
White 1955
White 1977
White 2000SM
White 2037
White 2134
White 2137
White 2220
White 2222
White 2837
White 2999
White 3077
White 3355
White 3900 F
White 4075
White 6477
White 7934
White 8000
White 8600
White 8800
White 8910
White Computer Machine
Nov 19, 2009 | Sewing Machines
White Sewing 1766 Mechanical Sewing Machine Logo
205 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
