Question about Sunbeam Kitchen Appliances - Others
Hi, I need to repair Sunbeam toaster model 20-3 AG. The center heating element is burned out. Where can I find the parts, the resistence wire, or an element replacement part? Bruce
5 Suggested Answers
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
cactus bob
  • 267 Answers
SOURCE: Can an old Toastmaster toaster be refurbished?
there is no manual forthe repair of toasters . but the toaster you have is a common one on e bay , i dont see one right now but there have been a few over the years , and a well used one sells for around 10.00 , it may not work but its great for parts ( i collect and restore kitchen appliances) so i would take a look . you might find a cream puff for 20 .00 and put yours into retirement ..... other than e bay there not a lot of resources out there for parts . good luck ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 06, 2009
espressonist
  • 1711 Answers
SOURCE: I changed the element in my Dualit toaster; still doesn't work
If I understand well the blackened wire is an overheated wire which it is probably but off in one point so no electricity comes to the element anymore.
However overheated wire in you metalic toaster is a very danger thing to have and need to replace all the wires you have noticed that they changed color or not look good contition.
The problem have been caused from a problematic element which is the one you have already replaced.
However you if after you replace the wires you need to inspect the toaster after some time in order to be sure that not any other element causing the problem.
Good luck.
Posted on Apr 02, 2010
espressonist
  • 1711 Answers
SOURCE: Our 4-slice toaster (model 4cbc) is only toasting
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
nicklemarr
  • 296 Answers
SOURCE: Where can I get my
Search google in your area for electronics repair. Or bring it to the nearest adult male you know. Toaster are the easiest to fix.
Posted on Mar 21, 2011
Old westinghouse toaster 1941
that part was almost replaceable.
Jun 11, 2008 | Kitchen Appliances - Others
Far right side coil panel not working.
Good observation!-- Let's take that a little further?-- Are you willing to tear into it, and check it out further?
Your toaster likely has 4 heating elements, correct? (Or possibly 3-- if the center shares toasting the 'inside' of both slices all the time?)
Anyway-- you are concerned with the outside element-- Something is 'open' in that circuit to that element only.
Can you remove the exterior, and get into the interiro, so we cn look for a broken wire?
BE SURE TO UNPLUG THE PLUG FROM THE OUTLET!!
Look for a supply wire, that has broken off, or one of the heating element wires has separated-- either from itself, or the junction where it connects to the power.
Temporarily you might be able to join the break-- but the permanent solution is to replace this element.
o replace the element, we will need make, model, serial number, and will have to do some searching for the part.
How far do you want to go on this repair?
Mack B
Jan 15, 2011 | Dualit 20084 2Slice Toaster
Center element not working. Only toasts on the outsides. Ref 875742/4yb-5003. Is this repairable or under warranty?
I believe that the center heating element in your toaster is burnt out. If it is new take it back to where you bought it. If it is under warranty usually only 90 days from date of purchase you can send it in but remember that must companies require that you pay shipping and handling and this could be nearly the cost of a new toaster plus it will probably take 4 to 6 weeks. If your toaster was very expensive you might also try a local repair shop, but again if they need to order the part it could take 1 to 4 weeks for repair.
Oct 09, 2009 | T-Fal Kitchen Appliances - Others
The centre element in my 4 slice model has gone. Can this be replaced?
Don't know if you can get the heating element as separate part. But, this can probably be repaired. It's likely either a burned connection/connector or the heating element is broken.
Bad connectors can be replaced, the heating element can be just twisted back together where it is broken.
Charlie
Aug 14, 2009 | Dualit CTS4E 4-Slice Toaster
Our 4-slice toaster (model 4cbc) is only toasting part of one side of the toast, as if a heating element has burned out.
Good Luck
Aug 05, 2009 | Dualit Kitchen Appliances - Others
Tp 409 smells burn when turn it on
I would advise checking the elements as well. It is possible that plastic has melted onto the elements. Try to Identify which slot the smell is strongest. If there is a spot where the elements do have some sort of foreign material melted to them, you may need to replace them.
I
Mar 08, 2009 | Toastmaster TP409 4-Slice Toaster
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Replacing the elements on a Dualit 2-slice
You can find out how to replace the heat elements and purchase replacements at the Dualit Repair Center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Nov 05, 2007 | Dualit 20247 2-Slice Toaster
Kitchen Appliances - Others Logo
Top Sunbeam Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
