Question about Garmin Nuvi 760 Handheld GPS Receiver
Sound is gone on Nuvi 750. Have reset all and turned on and off. Still no sound.. No voice no nothing Help
  • 2 more comments
  • Anonymous Mar 29, 2009
    no sound on garmin nuvi 750
  • wzucker Mar 29, 2009
    no sound on garmin nuvi750
  • ckatie Apr 07, 2009
    i had no sound after about 36 hours of use, so i returned my unit and got another identical one. today the sound went out it has been used for about 34-35 hours....im returning it gonna try the 780 if that one doesnt work im not getting another garmin!
  • Anonymous May 15, 2009
    No sound. Tried reset numerous times.
Undo the case with the two screws and disconnect the main battey and the back up battey and put it back together. this fixed the problem with audio and not turning on.
Posted on Jun 16, 2009
No voice sound on my GPS
Try to reinstal voice with garmin web updater.
Feb 10, 2014 | Garmin (010-00583-00) for nuvi 750/760/770
Tip
No Sound or Garbled Sound on a Nuvi Series GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Oct 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
No audio on my nuvi.
At some point you may have switched the unit off before it completed it's start up dance. This will wipe out the voice file more often than not.
You will need use Garmin's web updater and re-install the file for the voice you want.
Jul 19, 2010 | Garmin nuvi 750 GPS Receiver
No sound whatsoever on GPS
Maybe you have turned the FM modle on, which means the sound can only comes out from your stereo system.
Aug 24, 2009 | Garmin nuvi 780 GPS
Tip
No Sound Issue on the Garmin Nuvi Series
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin nuvi 350 GPS Receiver
I have lost my sound on my garmin 750 gps
I had a similar problem on my vacation. the voice stopped working suddenly. in my case i could get it working again by reselecting the voice (american/british etc) in the language section. for some reason it had reset to blank.
but i still cannot get the text to speech to work.
Feb 27, 2009 | Garmin nuvi 750 GPS Receiver
NO SOUND ON GARMIN 750
I had the same problem. I fixed it by going to settings, then to language, and then entering American English into the Voice category. Hope this helps.
Nov 19, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmins Nuvi 350 - voice interactive lost
I have the same problem with my Nuvi 350. It's only about 2 months old and the sound went. I turned it on the other day to use it and the sound did not sound right, it sounded like the speaker was blown. I turned it off and turned it back on and that was it, the sound was gone. I did everything possible and can't get the sound to come back. I called Garmin and now I have to send it in for repair. I looked around the web and noticed that Garmins have big issues with the sound going on the units. I hope they fix that issue.
Jul 28, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
384 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
