Hi I have a DBX 10/20 equalizer that appears to be working, based on lights modulating and settings, but I get no output when connected to my system. Can you recommend a repair source? I live in Cincinnati, Ohio. KC Wilson
SOURCE: DBX-1215 to Home Receiver
you should need a XLR-PL55 connector that has balanced connections.The PL55 is stereo,so that there is a balanced connections.
Posted on Aug 02, 2008
welcomejee
  • 10594 Answers
SOURCE: manual for dbx eq system set-up
Check out 12 Series User Manual might help you.
Posted on Oct 09, 2008
  • 5 Answers
SOURCE: how do i connect a pioneer djm 500 mixer to a dbx
You can use either (2) XLR mic cables or (2) balanced 1/4" cables running from the Master Out of the djm 500 to the dbx 215. Then you connect your amp to the outputs of the dbx 215.
Joey Clay
Posted on Oct 27, 2009
McLindy
  • 32 Answers
SOURCE: I have a dbx driverack
Test the XLR cables that go in and out of the dbx. It's kind of a long shot but I think it's the best place to start.
Posted on Feb 06, 2010
dunnbiker
  • 8546 Answers
SOURCE: My 1215 equalizer produces a hum when inserted
Wild guess - I had something just like your problem (including consumer dbx components) and it was ONLY with the track lighting turned ON. Replacing the lighting control DID NOT help but the problem up and went away by itself.
Sometimes hum can be defeated by rotating the orientation of a single power plug.
Just wondering: WHY do you feel the need to EQ the sub beyond its own controls? Though I don't have not pro-gear, I'd use a dbx-120 instead and save the EQ for something more in tune (pardon the pun) with its capabilities.
Posted on May 21, 2010
Mixer and an EQ & amp ?
The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
Jun 23, 2010 | DBX 1215V Home Equalizer
How can i set my drive rack,to stop the base line and the base drum from coming out in the tops
thats in the crossover on your rack you actually need separate amps one for hi and one for lows connected to your d rack
Jun 11, 2010 | DBX DriveRack 480 Processing Unit Home...
My 1215 equalizer produces a hum when inserted between the subwoofer output of the receiver and subwoofer amp. I am using the barrier strip inputs and outputs, rca tip to plus, shield to minus. I have...
May 21, 2010 | DBX 1215 Home Equalizer
How do i connect a pioneer djm 500 mixer to a dbx 215 equalizer
Joey Clay
Oct 14, 2009 | Audio Players & Recorders
No access to driverack 480 with belkin adapter
The Driverack Series all use a Null Modem cable for the connection to the Serial Port. A standard serial cable or female to female lead will not work, as the wiring has to be of the Null Modem type. A suitable lead should be available from your local PC supplier, failing that DBX can supply you with one also.
Hope that helps.
Jay
Feb 04, 2009 | DBX DriveRack 480 Processing Unit Home...
Manual for dbx eq system set-up
Oct 09, 2008 | DBX 1231 Home Equalizer
I want to open dbx file of out look Express in my computer
Hi download, extract from zip file and run -->LINK<--.
It's a stand-alone program, I have virus scanned, opened and tested this program.
Works fine
Regards
Philip
Jul 31, 2008 | DBX -215 Home Equalizer
Jul 30, 2008 | Audio Players & Recorders
DBX 119
Do you mean you are just going to play back dbx-encode tapes that have already been recorded? Or both playback and record new material? Please explain.
Aug 25, 2007 | DBX 1231 Home Equalizer
309 people viewed this question
 Grubhead
Grubhead
