Question about Dometic RGE400 Top Freezer Refrigerator
My 1995 Dometic 2611 runs OK all day but not at night
My 1995 Dometic 2611 runs fine during the day when we are up and moving around but quits at night (electric or gas - no difference). I have tried a fan in the control area with un certain result. All fuses are good and voltages seem OK on the power panel. Can't get the cover off the little panel (re-igniter?) that has the trermocouple lead. Do I need a new coil (cooling) unit)?
  • asal3660 Mar 11, 2009
    Mar 10, 2009 - Installed a Dinosaur P-711 control board and the refer has performed perfectly for 2 dsays. Problem fixed....so far,
  • asal3660 Mar 21, 2009
    Still performing perfectly as of today - 2/20/09 with the Dino board and the original cooling unit...so far-so good.
    Sniper:
  • 68 Answers
Yes more than likely the cooling unit is going bad. If your boiler tube is hot the cooling unit is no good. Your frig is 13 years old, it has reached its life span and beyond. A cooling unit or a new frig can be purchased from www.coachtech.info. Just send them an e-mail.
Posted on Mar 19, 2009
Have a space heater in the living room and one in the kitchen. Seem to work fine during the day but go out at night. What could be causing that?
These unit have a Pilot/ODS system built into them.
The ODS (Oxygen Depletion System) will shut these units of if the oxygen get to low.
This will sometimes happen more at night that during the day...people moving around more during the day, opening a door let more oxygen in.
Try cracking a window and see if the units stay on all night as a test to see if this could be the problem.
Oct 25, 2010 | Desa International Unvented Gas Space...
Rv ac throws the breaker when outside temp gets high, unit works fine at night when outside temp cools down
Clean evap and cond coils
Place hand on a/c if too hot during the day but cool at night
then freon is being restricted in the condensor
Cleaning coils may help days
Put a trickle of water on the condensor during the day for a test.
.If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
My rv air conditioner works fine at night but only clicks on during the day for about three minute intervals. It seems like the compresor should work harder during the peak heat.
First thing I'd check is the hydro supply to your RV. Test voltage at both times and see if it is the same. You can even buy a plug in tester if necessary, that plugs in to receptacles. It may be a case of everyone around you has AC etc on during the day and your incoming voltage has been lowered, thus AC will not work correctly, and at night when some others are off, your voltage comes back up to where AC will function properly. Especially likely if you are near the end of a power cable run. If you have access to a good generator even temporarily, try plugging into that during the day and see if it doesn't make a difference.
Jun 14, 2010 | Dometic Rooftop RV Air Conditioner
The airconditioner is drawing too many amps and is tripping the breaker during the day at night it seems to run ok
Check the condenser fan and see if it is running. If it's not it will cause the head pressure to rise and the unit will work harder. This will be more noticable in the heat of the day. Also check your air filter. Let me know what you find and we'll go from there.
May 22, 2010 | Dometic Rooftop RV Air Conditioner
Brand new Dometic rooftop ac,freezes up at night,does fine during day...??
This is common for most air conditioners and is normal due to humidity levels being higher at night causing more condensation build up and then freezing. Solution: Turn down thermostat at night to allow compressor to turn on and off.
Jul 26, 2009 | Heating & Cooling
Outside a/c fan quits but compresser still runs
it sounds like the fan is over amping itself and shutting down on thermal overload check the amp draw during running time and compare it to the sticker on the outside panel it should be running .9 amps, and it will over heat if it runs around 1.2 amps or above
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
I have a dometic rm 2611, does not cool
If you can , run it on gas and see if it is OK- if so, you probly need an element.
If it wnot work on gas or electric you need a new sealed system
May 24, 2009 | Dometic RM2193 Compact Refrigerator With...
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Rm 2611 will not run on gas when going down the road
Your voltage supply is being interrupted. The DC voltage needs to be at least 10.5 to work properly. If you are switching from shore to gen this can cause the interuption also. I presume the gas supply is staying on when you are traveling.
Jul 28, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
222 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
