SOURCE: HELP, H4 ERROR
The fuser isn't heating up on time. You could try turning the copier off for 30 seconds and turing it back on again to see if it goes away.
If it doesn't happen, there is a part that has to be fixed on the fuser to correct the problem. Usually it is the thermistor.
SOURCE: code H4 comes up when the sharp copier ar-5316 is switched on
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
SOURCE: I want a solution for a Sharp AR - 287 Digital Image problem
H-4 is an error code for the fixing assemblyand needs to be reset thru a simulation code, sometimes a power flucuation can cause this error and therefore may not need parts.
press #
press *
press clear
press *
when it is done properly the display will go blank
then enter 14
then press the start key, turn the machie off and then back on.
If the code comes back you'll need something for the fixing assembly
Good luck
Bob
SOURCE: problem on sharp copier ar m-236 h4-01
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
