Question about Acme Automotive ACMA680CS Typhoon High Volume Air Blow Gun
What's the best air compressor for a car paint job?
Hi, i need a little help buying a air compressor for a car paint job? i was wondering what's the best size for doing yourself paint, etc... i don't want a expensive one just one that just get the job done. i know it just going to be a one time thingy... well, any advice would be gladful and thank...
  • annette18061 Apr 20, 2009
    hi my husband has resprayed our minibus and it looks dull can you tell me what hes done wrong
  • 86 Answers
Painting requires lots of air! I want my compressor to have a MINIMUM 10 gallons or more capacity and provide 6-7 CFM at 90 PSI. The duty rating should be at least 50%. Many compressor have a label on them showing what uses they are well suited for. Start with the gun, the air requirements are usually printed on the packaging, use those as minimums! Good luck!
Posted on Feb 28, 2009
You will hear a variety of opinions on this subject...but I personally would recommend a compressor with at LEAST a 60 gallon tank with 5hp don't want to risk ruining a paint job because you didn't have enough air...bigger is always better! Bottom line, you will most likely be using air tools and sanders so you will want to have somewhere around 15psi @ 90 to get the job done. Good luck.
Posted on Apr 23, 2009
  • chris jacomet Aug 28, 2011
    certainly the larger the better, but if you get something with approximately 10 gal tank minimum and 3 to 5 hp and better an old oil type you should do fine. may take longer to paint and have to do over a few days, you can always use lacquer which is more forging since it is sprayed on dry and is easyily blended
Need to re paint my grille
automotive paints require a good clean and well prepared surface like light waterpaper sanding to remove any oily or fatty resedu and the correct undercoat before applying a new coatings otherwise it will not last chipping or peeling will occur.
May 06, 2013 | Cars & Trucks
Spray painting
It depends on what kind of spray gun you have. If you have a HVLP gun the pressure doesn't have to be as high, but you need a compressor that will keep up. The pressure is usually pretty low on these guns, about 15 PSI or less. The paint manufacture will usually give you a recommended pressure to paint their paint. A normal (old style) suction type gun takes more pressure, about 50 PSI. If you are asking this to decide on a compressor size, you will find that a one horse motor on a two cylinder compressor will not keep up. The newer supposedly five horsepower compressor will not keep up consistant pressure either. You need a five horsepower that runs on 220 and driving a belt driven two cylinder compressor minimum. You can get by on less, but have to wait half way during a coat on a car to wait on the compressor to catch up. This may be o.k. if you are just going to paint one car, but if you are looking to do this consistantly, then I would get a five horsepower motor on a two stage compressor. Make sure you drain the air tank of water and use a good air filter to remove moisture from the air before trying to paint. Hope some of this helps you.
Feb 16, 2012 | Bernina Sewing Machines
Need telfon ring for sears air compressure model No. 919.15294, she last a long time but the telfon ring bite it this week. need replacement ring.
If you need this part fast try going to a paint store that sells spray pumps . These things are most of the time stanard sizes eighter SAE or METRIC you should be able to match it up if you have the one you need to replace with you . Its a seal if its a little off it won;t matter as long as it seals and the fixture its tight it should work . I spray paint and have to make things like this all the time in a pinch to keep the job going until i can get to the supplyer . Give it a shot
Jul 10, 2011 | Craftsman Air Tools & Compressors
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
2008 Dodge Nitro Canada
I hate to say, being 2008 and have that many miles, from my experienced working many years at many dealership, your fighting against a brick wall, you can threat them with all kind of law suit, all it will come down to is repaint and that is the best they will do. I hate to say that they going to make you run around in a circle by the time they have exhausted you, you will settle just for a paint job. Those machine from factory, I wish I can say its an excellent job it does but you going to get some defect. In you case if you take it a good paint shop and highly recommended, than you will get allot better paint job than a factory and you shouldn't even have a problems with it and the new paint job will probably outlast other parts compair factory paint on your car. good luck..and I hope that help some
Oct 04, 2009 | 1989 Dodge Grand Caravan
you can buy any small compressor, will do the job, it uses very low volume of air. for blowers, paintguns and drills you need high volume compressors. so if the nail gun is all you will use it for, buy an inexpensive compressor and save money. plz rate-bozcro
Sep 10, 2009 | Air Tools & Compressors
Does this dental air compressor have a oil pressure safety switch?if so, where is it located? can I find a wiring diagram
Air compressors are designed to operate many different tools. The value of a commercial air compressor is many times greater than the purchase price because of the amount of work a single air compressor can perform. Dental air compressors are some of the most reliable because of the high-quality air they supply and precision tools they operate. As a result, dental air compressors can be adapted for a number of different tasks, including artistic air brush painting
1.Disconnect the air compressor from the dental tool air supply. Pressure and air supply rate-of-flow settings are different for air brush painting than for air delivery for dental tools.
2.Reset the air pressure on the tank to a range between 15 and 20 pounds per square inch (psi). The exact operating pressure for airbrush painting will vary, depending on the application and the type of paint used.
3.Reconnect an air-supply hose and a siphon style airbrush to the compressor.
4.Fill the airbrush's paint vile with lacquer-based paints. Test the air brush and paint performance on a piece of cardboard, or scrap piece of cloth
material before beginning the painting project. Every time the air compressor is connected to airbrush, or a new paint color is loaded into the brush, a short test spray should be performed. After each test adjust the air volume, and the paint flow in the gun to achieve the desired results8_16_2012_1_32_17_am.jpg
Aug 04, 2009 | Air Tools & Compressors
I need new brakes for my 2005 x type and I would like to know the best brakes to buy
Bendix, metallic. These are the best kind,but there is a drawback.
When using metallic pads you get what is called RAIL dust, this is
when the tiny pieces of metal from the pad stick to the car and you get tiny little rust spots on the paint job. So if using these you need to keep the car washed and waxed.
Apr 14, 2009 | 2005 Jaguar X-Type
Portable Air Compressor Comparison
Portable air compressors give flexibility to the job both inside and outside the working environment. They're powered by electric, gasoline or diesel engine. A larger portable air compressor often has its own carrying trailer with wheels and handles. You buy a compressor based on its horsepower, pounds per square inch (PSI) and cubic feet per minute (CFM). Choose a portable air compressor to make work quicker and easier. Figure the amount of power you need based on the type of job and air tools used. Know the cubic feet per minute (CFM), such as 5 CFM for small household tools and 10 CFM or more for wrenches or sanders. All air tools have these ratings. Select a gas- or electric-powered engine. Gas gives a higher reliability for frequent use and portability, but consider electric for enclosed areas for its lack of fumes. Pick an air tank based on amount of use time and tools. Large tanks are best for longer use with sanders or grinders and smaller tanks for less time, like wrenches and air hammers. Consider the pump type you need: belt for heavy use or direct-drive for light home use. The quieter belt-drive pump needs periodic oil changes. Buy an inexpensive, small electric portable air compressor for small jobs. These typically operate from a 12-volt power outlet and inflate a 14-inch tire in a few minutes. Get a 150 PSI, 120 volt motor pancake-type air compressor for home use. These light-use models typically carry two air couplers, allowing hook up of two air tools and adequate 25 feet or more air hose. Obtain a larger PSI portable air compressor for bigger jobs, like nailing, with longer continuous use capabilities.
Aug 27, 2008 | Acme Automotive ACMA680CS Typhoon High...
Acme Automotive ACMA680CS Typhoon High Volume Air Blow Gun Logo
7,041 people viewed this question
Top Acme Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Acme Tool and Hardware - Other Expert? Answer questions, earn points and help others
