Question about Poulan Pro Chain Saw 46cc 20"
Poulan chainsaw 46cc 20" chain
I need to readjust may chainsaw carburetor and would like some helpful tips.
  • 75 Answers
You normally have 3 screws - idle speed - slow running and fast running.
First take care as if it runs faster than idle speed that chain will be whipping around also.
Second you have to determine what is the problem. Is it faulty at low speeds or high speeds ? or won't it idle.
If it has turn stops fitted to the screws you only have a small adjustments either way.
If it won't idle, try turning in the idle screw a half turn - until the chain just starts to move slowly.
If its dying at slow speeds, get is going and slow turn the slow screw out until it starts to run a bit rough then turn it back in to the point where its running smoothly.
Bad fast speed can be caused by simple things such as a blocked muffler ( insects too - I had one blocked off by a mudnest wasp) - otherwise get it running at full and adjust the fast screw as per the slow one - out till its rough then back in slowly until its smooth.
Suggest before all this tho that you get it running with the cover off the carby and then give it a good squirt of carby cleaner first - it may just clear out any 'poop' thats there.
(Have faith even tho I have a Poulan with a carb that refuses to run on anything but carby cleaner. I have pulled it apart a few times and renewed all the perishable bits buts its a real pig)
Posted on Feb 28, 2009
I would like to see part digram? for poulan PRO 20"
Poulan currently offers 2 46cc 20" bar chain saws which are virtually identical
model PP4620AV, and PP4620AVX
if you are looking for a different diagram please include the model number you need in the post.
Dec 28, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain on my Poulan 20 inch pro will not tighten
If you've got the adjustment all the way out, you may need to remove a link or two from your chain or replace the chain. You can find replacement chains at
Sep 02, 2010 | Poulan Pro Chain Saw 46cc 20"
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain doesn't move
Sounds like the clutch is slipping due to oil collected on the inside of the clutch drum. Wash out the entire clutch assembly with spray carburetor cleaner and let dry. Make sure the chain can be turned freely by hand, but the chain doesn't droop from the lower bar edge. Hope this helps!
May 26, 2010 | Poulan Pro Chain Saw 46cc 20"
My poulan 360a chainsaw cuts out when used for 5 mins. when opening throttle to saw woods it does not respond and cuts starts again ok but will not respond to throttle. it is ok when motor is cold.
Check the fuel filter for plugging, the fuel lines for hardness/cracking/splitting. Clean or replace the air filter. Clean the muffler if plugged. Make sure that the carburetor fasteners are tight. Check the spark plug condition--gap should be 0.020" and the insulator should be light to medium tan color. If still having problems, the carburetor may need to be cleaned and serviced. Hope this helps!
Apr 19, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 3314 piston change, special tool needed???
Needle nose pliers. You would normally use a new lip when reinstalling it.
Mar 16, 2009 | Poulan Pro Chain Saw 46cc 20"
Runs bad like no fuel
well assuming this is your model:
--> poulanpro.jpg&s=hs
Chain Saw PP4620AVX 952802146
  • 46cc 2-Cycle Gas Chain Saw
  • 20" steel bar
  • Anti-Vibe Handle
  • Automatic Chain Oiler
  • Super clean air filter system
  • Tool-less Chain Tightening System
  • 2 Year Warranty
I would go to Poulan Directly and Voice your Complaint with them, they might make it right with You...
You can Contact them at:
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
or Via email/request form:
Good Luck!
Dec 13, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
347 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
