Question about Nintendo Wii Fit for Wii
Wii Fit Weighing Me Wrongly
Wii Fit says I weigh 12 pounds less than I do.This prevents me from gaining accurate results.
Balance boad is on carpet - should I put some sort of board underneath?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
You should probably put it on a board but if that doesn't work, you could try putting something weighing 12 pounds on the board or in your pockets or whatever.
Posted on Feb 28, 2009
My WW78 scale keeps giving an ERR message when I stand on it.
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
Feb 19, 2012 | Conair Weight Watchers® WW78 by Glass...
My Wii fit weighs me at about 20lbs less than all other scales (maybe I shouldn't complain). How do I resist it so it will be more accurate?
Are you doing it on carpet? Mine does the same and I put the board on a hard suface and it's accurate.
Dec 06, 2010 | Nintendo Wii Fit for Wii
The board keeps asking me to step off when I'm not on the board. It won't work with any game. It thinks it has someone on it when there isn't.
Hello :
Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom
(such as carpet), try using the foot extensions
If you are you using the Wii Balance Board on a plush carpet , try using the foot extensions. After you have installed the extensions, re-weigh yourself and check for proper results (within a few pounds.
good luck .
rate please !
Mar 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
What do you do when your wii balance board keeps saying please step off me and press A
Sorry to tell you but it has gone faulty, you need to take it in for repair. There are no serviceable parts inside.
Mar 18, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board keeps jumping in tightrope game
We had that issue one game and the problem was that we had multiple users all using the same Mii character but weighing between a range of 60lb between people. Because the fit uses weight to determine if you are actually jumping (since you're not supposed to break contact with the fit board) if one user weighs more than the previous person who's weight was used as the calibration, the second person will seem to be in a constant 'jump' state. Try resetting the weight for the Mii you're using, or just recalibrate between users. This totally solved our problems!
Jan 10, 2010 | Nintendo Wii Fit for Wii
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
The balance board yesterday said i weighed 190 lbs. and today it says i gained 20.3 lbs. what's wrong with it?
If I were you, I'd buy a scale to see if it was right (or a mirror).
Just kidding. Return it and buy a new one!
Jul 21, 2009 | Nintendo Wii Fit - Balance Board + Game...
Wii fit weighin too light!
I would suggest that you ensure that the board is calibrated properly and that you don't step on it until directed to do so. I'm sure you're already doing this, because it won't let you go on without doing so.
The other solution I would offer is to change the batteries in the unit, and ensure that you are setting the Balance Board on a smooth, sturdy, and flat surface. If you are on shag carpet, it will not function properly. If you have average carpet, try using the little adapters that attach to the feet.
Remember that for the purposes of this program, the exact weight isn't what is most important, but relative weight. Any time you are tracking weight loss, be sure to mark your progress using the same scale. If you chart the Wii vs traditional scales, you should notice that the decrease is the same, regardless of what your starting point may happen to be.
Jan 18, 2009 | Nintendo Wii Fit for Wii
Nintendo Wii Fit for Wii Logo
134 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
