Question about Poulan Pro Chain Saw 46cc 20"
I need help with a carburetor adjustment on my chainsaw.
I have a used poulan 4000 series chainsaw and need to adjust the carburetor. Would appreciate some helpful tips.
  • 398 Answers
This site gives alot of helpful hintshttp://www.arboristsite.com/showthread.php?t=5208
Posted on Mar 02, 2009
Set H&L jets oh a poulan p3314
I believe there is also a idle adjust.
adj. both L and H 1 1/2 turns approx from closed (bottom) for initial start up. check video links below, press the helpful button
http://www.poulan.com/ddoc/POUO/POUO2004_USen/POUO2004_USen__530165293-01.pdf
How To Easily Fix Chainsaw That Bogs Down By Adjusting The Carburetor
HOW TO ADJUST POULAN CHAINSAW CARBURETOR .
Jan 22, 2016 | Poulan Tools & Hardware - Others
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
How do i adjust carburator
I have attached a video from YouTube donyboy73. In it, he adjusts a carburetor for a Poulan 2150.
It won't matter which model saw you are adjusting, they would all have the same screws.
http://www.youtube.com/watch?v=3Lw0pJcEPYo
I hope this helps.
Jun 10, 2014 | Poulan 2055 2.0 Ci Chainsaw Hardware
How do you adjust the carborator on a 2.5 stihl chainsaw?
Most Stihl carburetors built after 2000 have limiter caps that prevent much adjusting. the standard for adjustable carburetors is 1 turn out on both high and low then set rpm of idle and high end to specs.
If you need to adjust the engine to get it running there is a problem somewhere else in the systems.
see a dealer like www.arcolawn.com for help.
good luck
Nov 07, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
My poulan chainsaw 2.5 ci farmhand boggs out when choke is turned off?
Check for plugged fuel filter, hard/cracked/rotten fuel lines, plugged muffler and air cleaner, or loose fasteners on the carburetor. If no help, dismantle the carburetor and check the lower rubber diaphragm for hardness or cracking. Make sure to have fresh fuel mix in the tank. If the L jet needle has a slotted-head, a small screwdriver can be used to back out the adjustment CCW about 1/4 to 1/2 turn. If the adjustments have 'D' heads, you will need to take it to a servicing dealer that has the proper tool. Hope some of this helps!
Apr 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan pro 220 chainsaw owner's manual for tune-up
you could try cleaning the carb and filter. make sure your fuel lines are clean too
Feb 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need an Idle Speed Adjustment Screw for a Poulan ProPP4218 Chain Saw.
Ordertree.com (Poulan authorized parts outlet)
http://www.ordertree.com/cms/contact-us/9790.html
Telephone - For Handheld or Wheeled Products contact us at 1-877-500-7499
I looked at "Gas Chain Saw PP4218 Types 1 & 2" IPLs. there are no carburetor illustrations. I suggest you contact them by phone. Please have your saw and a supply of common hand tools within easy reach before calling. HTH
Lou
There are often multiple carburetor manufacturer's used on the same model. They can easily help you determine what is on your saw.
Dec 14, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need adjustment tool for carburetor - where can find this
Hi
You can try to buy it from a shop where are Poulan chain saw for sale but I am not sure they do.
best rebards savumihai71
Dec 08, 2008 | Poulan Garden
Poulan 295 farm boss chainsaw
Try to adjust the air and gas intake pin. It is a screw type dial usually found sticking out the carburetor. You are tuning your carburetor, so you will have to test different adjustments until you get your desired running idle and power. I suggest you start with adjusting the air intake screws to decrease air supply going to the cumbustion chamber, It will probably make the chainsaw run when you give it a throttle.
Keep me updated
Mark
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro Chain Saw 46cc 20" Logo
822 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
