Question about Copystar CS-2114 Copier
Copy star cs2114
When you turn on it blinks c30
  • 51 Answers
C-30 means scanner motor problem.
If there is no continuity on the motor coil - replace with a new one
The home position switch may be disconnected, or defective test for continuity, replace as needed.
check for scanner pylly bindng, and lube scanner rails with light oil.
Good Luck!
Posted on Sep 10, 2009
Reset service message in Volvo V50, S40, C30, C70 and other
Reset Volvo service reminder indicator or maintenance messages after changing oil, filters and inspecting brakes and suspension.
  1. Press and hold trip reset button,
  2. turn on the ignition,
  3. wait for the yellow warning light to start blinking,
  4. release the button and wait for confirmations sound,
  5. turn off the ignition,
  6. turn the ignition back on to check if the service message is gone.
This procedure will reset messages:
This also works in any other modern Volvo car, like: C30, C70, S40, S60, S80, V40, V50, V60, V70, XC60, XC70, XC90.
More details over here: Volvo reset service reminder indicator
on Feb 13, 2015 | Volvo V50 Cars & Trucks
Why is the DATA light blinking on Sharp model MX-2300N
If something is stuck in the rendering process this will happen. To fix it, first make sure the machine is in copy mode then press:
Pound, Star, C, Star
66, start
10, start
execute, yes...wait for a minute while it processes, then it will reboot.
this will clear out anything stuck in queue
Skelton Business Equipment Houston Copiers
Jun 02, 2014 | Sharp MX-2300N Color Copier
How do I reset abs lite on 08 c30 volvo
ABS light can not be reset. You need to fix the issue that's coming the light to turn on.
Aug 22, 2013 | 2010 Volvo C30
Volvo c30 How do I reset the maintenance remider message.
1. turn ignition to I
2. depress and hold trip button
3. turn ignition to II(while still holding trip button)
4. in about 5-7 seconds warning light(yellow triangle) begins to flash
5. release trip button WHEN yellow triangle is flashing(it flashes 5 times, if you wait for it to stop flashing, it will NOT reset), turn ignition off
Mar 02, 2011 | 2008 Volvo C30
Solution for "c30 code on Mita DC 1255
A C30 code is as follows straight from the Tech Manual.
.Timing switch fails to turn ON 2.5
sec after scanner motor starts to
turn in normal direction.
.Home position switch fails to turn
ON 6 sec after scanner motor
starts to reverse.
.Defective scanner motor
.Defective timing switch
.Defective home position
Also check the scanner rail some of the seals on the rail around were the motor sits turn to gunk and will stop the scanner assy from moving.
Jul 01, 2009 | Kyocera Mita FS-C5016N Printer
Software update for persona c30 card printer by fargo
You need to be a little more precise on your question, I am not sure if you are asking for new drivers for the c30 or firmware? or you have it already and dont know what to do. I'll assume its the first.
go to to download the latest printer drivers for your C30. Also the firmware is up to 4.6.3 i believe.
thank you
Dec 05, 2008 | Fargo Persona C30 Thermal Card Printer
New ctg. change problems
In the printing preferences there is an auto detect ribbon button . you should select it.
Your ribbon will be updated. Also if printer asks you if the ribbon is correct select yes. The printer will then print on whatever ribbon you have intalled. This doesnt work with test prints
Dec 26, 2007 | Fargo Persona C30 Thermal Card Printer
Copystar CS-2114 Copier Logo
59 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
