Question about Keurig Elite B40 Coffee Maker
Does not dispense water unless you pinch vent in water tank.
After pressing BREW, water does not dispense. At the end of the cycle, the coffe maker pupmp would come on as expected and would try to refill it's internal tank - but would stop quickly and the display would soon show READY and only the largest cup icon in the display. Trying again, and noticing water dripping fron the vent in the reservoir, I plugged the vent during BREW and coffee started coming out of the dispenser. If I do this everytime, plug vent during BREW and leaving it alone during the pumping, it seems to work Ok. Any ideas?
If your Keurig is putting water out the vent and back into the reservoir. Open the front, using a flashlight and a toothpick, clean the coffee grinds out of the little hole in the needle that pierces the K cup. When it becomes clogged with grinds the water either has to come out the vent or the coffee maker will burn out. It is a safety mechanism.
Posted on Feb 15, 2011
    Problem Solver:
  • 9 Answers
It sounds as though the valve between the resevoir and the vent may be bad or stuck in the open position. If you read my earlier posts this would stop any vacuum from being created in the resevoir until you "pinch" off the vent. Changing this valve is tricky but very doable. The problem is getting parts which is near impossible. If you have or had a warranty call Keurig direct.
Posted on Mar 05, 2009
My bunn 10 coffe maker just died
not brew if no water coming in to filll the tank
Jul 11, 2014 | Bunn GRX-B
Keurig b60 won't dispense water
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
cycles if you notice any residual taste.
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Dec 14, 2012 | Keurig B60 Coffee Maker
Won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
How do I clean my coffee maker?
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee is coming out all around the coffe dispenser and very little through the dispenser.
brew unit filters are blocked. take out brew unit, remove screws and clean and replace stainless steel filters.
Jan 27, 2010 | Miele CVA615 Espresso Machine
My gaggia coffee machine hasn't been used for a few months and now won't dispense hot water through the coffee unit
First remove the screw and screen then press brew button to run water, if that works clean screen and reassemble, if not you will have to remove the allen wrench screws and clean the diffuser and vlave spring.
Aug 09, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Keurig Elite B40 Coffee Maker Logo
3,308 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
