Question about Epson Stylus R265 InkJet Photo Printer
Epson R265 printer problem
Hi I hope you can help me, I have an Epson printer, I have just changed all of the ink cartridges - but when I try to print anything it all comes out in different shades of blue?
    Sergeant:
  • 199 Answers
TRY HEAD CLEANING
Posted on Feb 28, 2009
Epson R265 - prints blank (new inks & paper loaded)
Check the cartridges installations and make sure they're well installed.
Make sure the plastic tab around the new cartridges is completely removed.
Disconnect the printer completely and re-connect after a while.
Turn it off and on.
Problem solved?
Uninstall and install the printer again.
Hope this helps.Thanks!
Nov 10, 2011 | Office Equipment & Supplies
EPSON R265 cd/dvd printer can not print in black colour I have tried to reintall the driver but still can't print in black ink. Other colours print well. Ink cartridges are new.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Jun 06, 2011 | Epson Stylus R265 InkJet Photo Printer
Ink light on
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Apr 25, 2010 | Epson Stylus R265 InkJet Photo Printer
I have an Epson Stylus R265. It is telling me all
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson r265 keeps printing purple pictures I have installed new cartridges and done a head clean several timesbut i just won't budge
You probably need to purge the yellow ink channel. Use the cleaner found in refill kits and gently force the cleaner through the channel where the yellow ink cartridge attaches.
After cleaning, you will need to "charge" that ink channel either by many cleanings or by forcing the yellow ink into the channel before installing the cartridge.
Nov 03, 2009 | Epson Stylus R265 InkJet Photo Printer
Hi, I have just changed the yellow cartridge on my R265 with proper epson ink cartridge and it is saying that it is incompatible. Can you help please?
Hi If you are using compatable inks try taking the ink cartridge out and put it back in again try this three or four times to see if it will accept it if not try a different cartridge you can sometimes get a duff one The earlier models have a different cartridge than the later models epson altered them and changed the chip
Oct 25, 2009 | Epson Stylus R265 InkJet Photo Printer
My Epson R265 prints all of the colours green
Sounds like colour contamination to me.
Check the carts are in the right slots.
then print until it clears the problem.
May 09, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson R265
Both redlights are flashing, and I need to change the waste ink any one help please
Apr 24, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus Photo R265 icc problems
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Feb 12, 2008 | Epson Stylus R265 InkJet Photo Printer
INK CAPACITY DISPLAY
This seems to be a "feature" of this printer with compatible cartridges although I'm sure it wouldn't be possible to get Epson to admit it. I have seen the same thing on other R265s and I haven't found a solution a yet. As far as I know, it doesn't affect printing - as long as there's actually ink in the cartridges it will print, despite what the Epson Status Monitor says, but YMMV.
Sep 20, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
339 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
