Question about Tools & Hardware - Others
Using alot of hot surface ignitors
I have put 3 hot surface ignitors on my furnace this heating season.Is the ignitors I'm putting on defective or do I have another problem with the furnace?
  • 1 more comment
  • stevehottech Mar 01, 2009
    The furnance is sized correctly. The ignitor goes out about every two months.
  • Thomas F. Schneider May 11, 2010
    Maybe try a different brand? Interesting some ignitors we install and seem to never change but other units on the same roof seem to get changed a lot,but even then not more that twice a heating season.
    Sorry I couldn't be of more help.
    Is the furnace sized correctly or is it constantly gfoing off and on fairly quickly?
  • 67 Answers
Don't touch the surface of the igniter when handling it, and don't bind the mounting bracket when you tighten the capscrews, the bracket and igniter should be firm and no loose/movement if you try to move the bracket. also make sure the igniter is going back off after the burners light
Posted on Jun 25, 2009
Need "hot surface ignitor"
go to any heating supplier and ask for a universal hot surface ignitor, it comes with brackets to fit most furnaces
Dec 28, 2015 | Heating & Cooling
Hey there. first timer hook in up a payne furnace (no ac) to a analog thermostat (no c receptacle) using a standard 14-3 wire. 3 amp fuse blows every time before fan even kicks on. furnace control panel...
hook up r to r, w to w, leave the rest alone for now until someone can see what you have done. If the furnace has a sparker or hot surface ignitor, set the heat anticipator for .8 amps. not .4 or less.
Nov 15, 2014 | Heating & Cooling
Lighting pilot on Ruud 80 plus furnace?
Hi, There is no pilot and the flame is lit by a hot surface ignitor... The hot surface ignitors go bad frequently...you probably need to replace that...
Here is a tip that will help you try to figure out why your furnace is notworking.
BasicFurnace or Heating System Troubleshooting
heatman101
May 14, 2011 | Ruud Heating & Cooling
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
I have a 90 plus Ruud furnace that will work when I light the furnce with a match when the furnace is calling for heat
Sounds like the ignitor. Your unit most likely has a hot surface ignitor. The hot surface ignitor is located in front of your burners and usually has two white wires leading you to it. It is a wear-and-tear item that can be expected to need to be replaced every couple of years or so. It would not hurt to keep a spare near your unit at all times.
How to test a hot surface ignitor
Mar 29, 2010 | Heating & Cooling
I have had to replace the hot surface ignitor every year (its 4 years old and I have replaced the hot surface ignitor 3 times) on my furnace--is this a problem with all these furnaces or did I get a lemon?
I would check the grounding from the circuit board to cabinet, the ground coming in to the power of the furnace as well as the ground lug in your panel box. These furnaces are polarity specific and the wrong polarity or a loose ground will effect the longevity of the ignitor. Always buy a spare.
Jan 18, 2010 | Goodman GMS80903BNA Heater
RHEEM RGLE-10EQAGS Gas Furnace - Intermitent. Fans come on, Hot surface Ignitor comes on, then sometimes Gas Valve opens and all is fine, Other times, gas valve doesn't open and Hot surface Ignitor goes...
The sequence is Igniter comes on, valve comes on, flame sensor senses flame. If no flame is sensed after 3 tries, a lockout occurs. If you have a volt meter, check for 24-27 Volts AC coming to the gas valve, if your getting voltage to the valve but no gas, your gas valve is defective. It could be a intermittent problem, no matter, still a bad valve. if no voltage to valve, defective circuit board.
Dec 29, 2009 | Heating & Cooling
Why does my furnace gas valve keep going bad
Check the ground wire to the gas valve or the wire in the middle of the gas valve that says mv--pv, and that is a ground..
Dec 19, 2009 | Heating & Cooling
Have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Dec 04, 2008 | Heating & Cooling
Furnace will not come on but thermostat is showing information
turn off power to furnace and open the front panel and see if you can see burners and gas valve and Hot surface ignitor.
If you can. turn furnace on and watch to see if the ignitor glows.
Let me know what you find. If it doesn't glow you probably have a faulty Hot surface ignitor.
If I had make and model number I should be able to find the part
Nov 16, 2008 | Honeywell Electronic Programmable...
Tools & Hardware - Others Logo
212 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
