Question about Sharp AR-M205 Copier
Sharp ar-m205 error code E7 11
sharp ar-m205 shows error code E7 11 when scanning
  • Anonymous Mar 13, 2014
    Sharp Digital photocopier Ar-m205 service menual
  • Anonymous Mar 24, 2014
    My sharp ar m205 is showing u 2 I need the solution
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
    New Friend:
Remove the platen glass and clean make sure the white correction was clean if not just put a bond paper in white correction and paste to it, also clean the mirror will also help.
Posted on Jul 06, 2013
  • 37 Answers
The problem is on the scanning unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
Posted on Mar 01, 2009
Sharp ar-m205 showing e7 error code
Duplex model memory error/ Image data error
Detail 1. The memory capacity for the duplex model
machine is wrong. Insufficient memory
capacity.
2. Duplex setting is set for a single surface
model.
Apr 08, 2011 | Sharp AR-M205 Copier
Sharp ar-m205
L1 indicates the laser mirror motor is bad. The laser would have to be replaced to fix properly.
Jul 29, 2010 | Sharp AR-M205 Copier
My error message is E 7 flashing. After leaving it off over night it worked for a couple of copies. Now I am getting the same error message E7.
press and hold the copy key the second part of the code will show then go to google and type in "sharp ar-m205 E7-xx"
where xx is the last of the code you should get an answer there
Jan 12, 2010 | Sharp AR-M205 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
I need help regarding our scanner. Thanks.
The problem is you don't have enough memory to scan A3 in 600dpi. You can either try lowering the dpi or add additional memory.
May 20, 2009 | Sharp AR-M205 Copier
Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
Mar 19, 2009 | Sharp AR-M205 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
System settings on Sharp AR-M205
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
Dec 18, 2008 | Sharp AR-M205 Copier
Sharp AR-M205 Copier Logo
3,495 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
