Question about Microsoft Wireless Optical Desktop
I am having the problem of my keyboard and mouse freezing up all of a sudden. I can unplugg it from the usb port and plug it back in then it works for a while then freezes up again. ANYONE have any ideas?
  • mjaxson1973 Mar 02, 2009
    been there done that got any better ideas
    Sergeant:
  • 239 Answers
Try replacing the batteries. sometimes that helps.
Posted on Mar 01, 2009
I have an msi motherboard b75 ma g43 when i turn my system on the screen freezes at 99 appearing on the botoom right side corner of my screen.my mouse and keyboard are also not working.
Check your RAm and that you have the keyboard connected to a working port. A modern computer will not start(usually) without a keyboard. If your keyboard is a USB one then plug it into the front.
Jul 24, 2013 | Computers & Internet
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
When i plug my dynex wired mouse into the usb it says unknown device. it worked before it just suddenly stopped.
It may be your drivers are uninstalled.So you can install them again to make your mouse run.
Apr 06, 2011 | Dynex Optical Mouse
Suddenly my mouse stopped working and the red light stop on it as well. What shall I do?
dear mario
it seems to be a problem with the mouse cable.
shutdown your computer and remove the mouse cable and replug the mouse again.
now start your computer and see is it working now
if no , then if you have a USB mouse try using it on another USB port
else you have to purchase a new mouse and plug it in.
thanks
Gagan
Mar 17, 2011 | Ideazon Reaper ZMS 1000 Mouse
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
My mouse is freezing time to time.it works perfectly for a period and at a moment it's start to freeze. the freezes are not the same:some are shorter,some are longer and some times i have to remove it from...
Try to use a differnt usb port sounts like a possible conection shorting on the mouse cable its self, if u shake mouse to try create this error and error apears then there is a conection fault goign to mouse and it is shorting out the usb.
Get new mouse :P
Nov 28, 2009 | Razer Diamondback 3G Gaming Mouse -...
My wireless mouse freezes
I had a similar freezing problem with a wireless Logitech mouse and also a problem with the wireless keyboard, sometimes keystrokes would not register and sometimes they'd repeat a dozen times.
I was not able to fix the problem, so I got a Microsoft wireless mouse and keyboard, hoping it was a driver conflict that wouldn't affect both products. Wrong. The exact same thing happened to the Microsoft mouse and keyboard.
The cause of the problem turned out be that I had the receiver plugged into a USB hub along with several other devices. Moving the receiver to one of the USB ports in the back of the PC fixed the problem.
Apparently these wireless desktop devices don't like sharing USB resources with anything else.
Apr 17, 2009 | Microsoft Wireless Optical Mouse USB...
Why does my mouse freeze?
Possibly a bad mouse.  Either try another mouse on that same port or try that mouse on another computer.  If you want to, try that mouse on another USB port on your computer
Mar 07, 2009 | Logitech Wheel Mouse Optical
Weird problem with easy call
If there is a dongle plugged into a USB port, try another port, i have a logitech wireless desktop, and it used to have probs when connected thru a specific USB port, also reinstall the drivers and check batteries.
Mar 31, 2008 | Logitech EasyCall Desktop 967689-0403...
Microsoft Wireless Optical Desktop Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
