Question about Baumatic Alabama Gas Kitchen Range
Baumatic Alabama wok burner won't stay ignited
I have a Baumatic Alabama and the triple crown wok burner won't stay ignited. I have cleaned the igniter and the thermocouples. Gas is getting through and ignites, but won't stay ignited when I release hob burner knob.
  • 1462 Answers
SOURCE: NEFF Extrawide 6 Burner Gas
try local service agent for appliance care which covers neff bosch and siemans
Posted on Aug 05, 2008
  • 38 Answers
SOURCE: When you release knob from ignition burner
Check that the sensor is in contact with the flame.
Posted on Nov 22, 2009
SOURCE: Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
Posted on Jul 05, 2010
SOURCE: Baumatic B40 Gas Hob : Gas not staying on.
have the same problem with two hobs and one of them is baumatic and i solved the problem, it isnt a manufacture problem but indeed its dirt problem, next the ignition there is a heat sensor that works on magnetic source you should clean the very top of it with a knife by passing it you should remove the black dirt and then brush it with a t
Posted on Sep 14, 2013
  • 48512 Answers
SOURCE: baumatic oven ignition works but rest of electrics don't. What is the cause?
do a google .com search
Posted on Feb 03, 2015
THE GAS OVEN DIES WHEN YOU LEAVE KNOB
are you turning it after it lights before releasing the knob
pushing it in starts the piezo spark but turning it lets in the gas
Jul 15, 2016 | Smeg C6GGXU 24" Freestanding Gas Range...
Delonghi triple burner ignites but wont stay on
If it goes out as soon the ignition stops the thermocouple needs replacing
Oct 05, 2013 | DeLonghi DEBIG24SS Gas Single Oven
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
Front burner will not light the igniter is good it woks in the other burner and i put a good igniter in the burner and it will not work
What happens when you use a long match or a long butane lighter? Does the gas ignite?
Since the igniter is working in another burner, then either the gas isn't getting to the burner (sealed burner blocked), the spark is being blocked or the electrical connection to the igniter is bad.
Take apart the burner and clean the openings. Make sure that the hole in the part that slides over the electrode is clear (use a needle or the wire from a twist-tie). See page 28 of the manual. (available online from http://www.geappliances.com/service_and_support/literature/ . Enter the model and click submit). Make sure you replace the parts of the burner correctly.
My range also has an orifice at each burner that could be blocked. Turn off the gas before investigating this. Look at the instructions for converting the range from NG to LP - this should be attached to the back of the range near the regulator. This will tell you how to access the orifice and what size wrench to use. I believe my range uses 10 mm.
To check the wiring, you may need to lift the cook top. Often the top is secured with clips on the left and right sides.
I hope this helps.
Jun 25, 2011 | Hotpoint RGB745 Gas Kitchen Range
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
Baumatic Alabama Gas Kitchen Range Logo
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Vitaliy Gins
Vitaliy Gins
Treefrog15
Treefrog15
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
