Question about HP Compaq nx6325 Notebook
My hp compaq laptop nx6325 refused to charge its battery. It works normally with the ac adapter but goes off whenever I remove it from the ac circuit. The same battery was taken to similar laptop for charging and it was charged to 100%. But when returned to my own, it could not charge it. A technician advised me to check the charging point of the laptop from where the laptop battery gets its power for charging. When I checked it with my multimeter, it gave me 3.5V as against the 10.5V rating of the battery. Does this mean that the charging point on the laptop is faulty? How then can I get it repaired? Do I need to replace it? Please help and advise me as to what to do.
  • bv0175 Apr 06, 2009
    it comes on and works only when the ac cord is plugged to electricity. once th eac plug is removed, the computer dies. at first, the computer would recharge the battery slowly. even at that, it would never charge it 100% full. now, it simply wont charge at all. i bought anew battery and the result is the same.
  • 3,940 Answers
If the battery charged in another system, but not in yours, then most likely you are looking at a motherboard replacement.
Average cost for motherboard is around $200, if you have it installed by a technician, another $100 or so.
Posted on Feb 28, 2009
No power on
If the laptop battery is normal, but can not boot, check the power switch. Laptop power switch using a micro switch.
Check the power switch circuit when the power switch is in addition to checking the performance is good outside, but also check the external circuit components for damage.
If the battery power for laptops. But is not charging properly, or does not use the power adapter, then it should be checked laptop power interface circuit and peripheral components.
Sep 23, 2013 | HP Compaq nx6325 Notebook
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
Nx6325 battery
If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by using Device Manager
1.Open Device Manager
Right click on My Computer->select Properties->click Hardware tab->click Device Manager
or if you're using Vista or windows 7,type "device" on the Start menu and select Device Manager
2.Expand the Batteries category
3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Aug 17, 2012 | HP Compaq nx6325 Notebook
I am unable to charge mt battery on an HP Compaq nx6235. It will not work even with the power cable pluf=gged in. Tried everything but unabke to get any power
You can try hp compaq nc6120 battery as a replacement battery for your HP COMPAQ laptop. The Business Notebook NC6120 battery meet or exceed the original Business Notebook NC6120 notebook/PC batteries. Buy this rechargeable Li-ion HP COMPAQ Business Notebook nc6120 battery pack is cost-effective now.
Sep 14, 2011 | HP Compaq nx6325 Notebook
Hi all please i need a hardware specialist who is conversant to the HP compaq 6735s AMD sempron 1gig ram notebook to help me on this one i made a mistake trying to use the ac adapter for another hp...
internal component failure close to adapter socket Maybe user serviceable problem with recent surface mount components not really repairable by consumer
Sep 06, 2010 | HP Compaq 6735s Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Compaq nx6325 laptop will not power up
Perhaps try taking the battery completely out of the laptop for 5-10 minutes and then replacing it and trying again. My Dell wouldn't work on battery alone but was fully charged and leaving the battery out for a while before replacing it worked for me. Also keep your eye on how much the battery charges. It may be a faulty AC adapter also. Best of luck.
Sep 24, 2007 | Toshiba Satellite Pro L300 Notebook
HP Compaq nx6325 Notebook Logo
688 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
