Question about Dell Latitude D600 Notebook
Power cable i put toshiba power lead into my dell laptop now the bios screen has come up and the laptop is making a clicking noise and will not go no further than the bios
  • 3,940 Answers
If the system is posting and you can access the BIOS, then the ac adapter is probably giving the system enough power. Remove the HDD, see if the Clicking goes away and see if the system will boot to a WIndows XP CD with the HDD removed. (Most clicking issues in a portable are drive related.
If the system will post and boot to a CD with the HDD removed, then most likely the HDD is bad and will need to be replaced.
If the noise and boot problem do not change, then I'd see if the system runs normally with a Dell power adapter next.
Posted on Feb 28, 2009
Cleaned fan for laptop, now screen does not show anything
Depending on the make/model the video cable on a laptop can be a bit tricky to seat properly. Just unplug and reseat the cable - usually there is a pretty definite feel when it seats fully. It's unusual for laptops to have dip switches any more as most settings are now handled in BIOS.
May 17, 2017 | Toshiba Satellite M205-S4806 Notebook
My Laptop wont start properly. It just starts, shows Toshiba The leading Innovation message and goes off. I then get a blank screen with a cursor at the top left hand corner. Power cable is working,...
This could be a failed hard drive. As soon as you turn on the computer, go into BIOS (I think you hit the F2 key on Toshiba systems) and check the list of IDE or SATA devices. If you do not see a hard drive model number there, that is your problem.
If you do see a hard drive, you may be able to get it to work with a System Recovery CD. It may have been corrupted by a virus or power failure during a write operation.
Jan 06, 2011 | Toshiba Computers & Internet
Started up my dell inspiration 4100 laptop and it says no primary boot up devices and makes a click noise ,i went into the bios setup and it says down the list harddrive none constantly please help as just...
You must remove the battery for 12 min, and start your computer with the power cable.
Try opening the bios setup and change the boot order making harddrive no.1 in the boot order.
If all that not working, just press F12 and setup a new windows copy, may be the windows copy is damaged.
Jan 30, 2010 | Dell Inspiron 6400 Notebook
My dell inspiron 1525 laptop is so shouting 2 months onwards.please respond n giv me answer asap
Try updating BIOS from Support.dell.com http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
click here ----> Drivers 3 on this list is bios make sure it is XP or vista and also install chipset driver & restart before doing this try this Shutdown the whole system,take out battery & cable Press and hold power button for 10-20 sec and put the battery and cable in & then do this & have a try
Good luck
Jan 13, 2010 | Dell Inspiron 6400 Notebook
Blinking toshiba satellite A 05-54547 problem
A blinking monitor just might be a loose connection of the main display cable that runs up the left side of the display and connects to the motherboard. Also check the two wire cable attaching the inverter to the screen. The bezel of the screen will have to be removed as well as the power strip and keyboard to check the display cable. Remove the lcd screen from its hinges and look behind the display, there is a flat cable that plugs into the top edge of the screen. This cable has a habit of getting loose and falling out of the socket.
Now there is a chance that the BIOS of the laptop needs to be updated. There are many instances where the display starts acting up and a BIOS update is the correct action to take. Go to the Toshiba support site, put in the model number and then put in your operating system. Scroll down to where the BIOS is listed under downloads/drivers. Download and install the new BIOS, reboot.
Nov 08, 2009 | Computers & Internet
Hook up dell laptop to docking station: I have a dell lap top inspiron 1721 and a dell model # PRO1X docking station, I would like to hook it up in my home office. I have never done this before and just...
this is easier than you think my friend, firstly put the dock on your desk, plug in power lead, network cable and monitor cable, place laptop on dock (making sure it clicks into place) turn on dock and monitor and your up and running
Oct 16, 2009 | Dell Inspiron 1721 Notebook
Blank screen
Any hard disk that makes clicking or metallic noises is faulty, especially when POST error message no bootable devices detected.
To confirm go into the BIOS setting and see if the hard drive is detected, if it cannot detect the hard drive then it is definitely faulty.
Replace the hard drive and install Windows on the new hard drive to get the computer working again.
Aug 01, 2009 | Toshiba PSAFGU-058002 Notebook
My toshiba m200-c2100d shows TBX error on left top side on the screen when i turn on my laptop.i cant go into anywhere like bios,etc..only toshiba logo reamins on the screen.
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Jan 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Dell Latitude D600 Notebook Logo
70 people viewed this question
Alun Cox
