Question about Microsoft Windows XP Professional
System Shutdown error occurs on running cmd
When i run my cmd or and cmd applications system shutdown dialogbox appears which cannot be closed. Is it a virus? How to remove it permanantly ? It can be removed temporarily by running "shutdown -a" command on cmd. But i want some permanant solution.  Plz help
  • 20 Answers
It is a virus because that what happened get it wiped out
Posted on Feb 28, 2009
Why does my computer almost always come up with a black box say something to the effect of "Task Manager is closing background programs......" when I try to shut down?
There are many "processes" that run in order to provide services to the user and the application programs you install. I've seen system with as many as 85-100 processes running with no actual applications open. Occasionally, these processes take extra time to close down if there are other processes preventing them from doing so immediately at shutdown. To avoid corrupting the processes, the OS alerts you, the user to the extra time needed so you don't think there are any problems. You may have the option to force them closed, but unless you are willing to risk a corrupted file, doing so is not wise. Be patient and wait. This is a normal occurrence that will happen from time to time.
Oct 03, 2015 | Microsoft Computers & Internet
Tip
Tips & Tricks of Windows Operating System.
1) To check whether your window os is activated or not goto Run -> type slui & the window of activation status will appear.
2) To verify the drivers software is sign up by a valid signature certificate or not just type sigverif in run and follow the wizad (ie press start)
3) Various log windows options functions (Goto run and type the following) :->
i.) shutdown -s (for shutting down of computer)
ii.) shutdown -h (for hibernating computer)
iii.) shutdown -l (for logging off computer)
iv.) shutdown -r (for restarting computer)
v.) shutdown -i (gives graphical interfaces)
vi.) shutdown -p (shutdown without any interfaces of messages to administrator account)
vii.) shutdown -f (shutdown forcefully)
viii.) shutdown -s -m\\computername -t 30 f
on Apr 27, 2010 | Computers & Internet
Why do I need to run Chkdsk utility?
Chkdsk it is command for harddrive disk checking this command run on command prompt. This command is used for recover and fix errors on harddrive. When your computer's harddrive ahs bad sectors or any error it run slow and shutdown or restart suddenely. You can fix this problem with "chkdsk" go to start menu->command prompt then type ni prompt "chkdsk /r" without "" then it ask for press "y" press "y" then restart computer then when it start it will fix and recover errors on harddrive. Let me know if you need further assistance. Thanks for using FixYa.
Oct 03, 2010 | Computers & Internet
After i use partitionmagic to merge drive (D & E ) and rename to D the Drive D disappear and wheni check error it shown Error #1520 Externak attribute header mismatch How to solve this problem
This error occurs when the PC hard disk has error(s) and your using particular software as you have mentioned like partition magic. To solve this problem shut down all your applications and running software.
If you are using Windows XP
Go to Start>Run>In the run box type cmd
A black Window will open its called CLI or Command line interface. In this Window run the following command on the C partition CHKDSK /F if the message appears"Check the system next time the system restarts (Y/N) type "y". then type "d:"to enter D partition. When the D prompt (D:) appears type the same check disk /Fix command which is "CHKDSK /F" and hit enter.
Similarly repeat this command for all the partitions.
If the this option statement appears "would you like to force dismount on this volume? (Y/N). Select "Y".
If you are using Windows Vista or Windows 7 then when you perform the first step which is Start>Run>In the run box type cmd before hitting enter in the start menu look for a small black icon named cmd on the top of the start menu. Right click it and select "Run as Administrator" When the black cmd window opens all the steps after that are the same as described above.
Good Luck!
Jul 29, 2010 | Computers & Internet
Slow motion, fuzzy scratchy noise, shutdown problems.
the same thing happened to me
this is not a device error but a OS error
use system restore to restore the system to a date before this error started occurring
this a totally random error that happens due to a code fault
just restore the system to a date where this problem was not there and you will be fine
Sep 29, 2009 | Alienware PC Systems Alienware M17...
Smple script for graceful shutdown of Windows OS
a simple batch file could be used
down.bat
@echo off
IF "%1"=="" GOTO DEFAULT
IF "%1"=="a" Shutdown -a
GOTO END
Shutdown -r -t %1
GOTO END
:DEFAULT
Shutdown -r -t 30
:END
This batch file accepts the inputs as follows
"down.bat" This will shutdown in 30 secs and is default
"down.bat 120" This shuts down in 2 mins
"down.bat a" This aborts any shutdown operation.
Hope this is what your after
May 07, 2009 | HP 3000 XR (j4367a) UPS System
Start menu wont show up
application softwares &system software in start menu
Feb 02, 2009 | Microsoft Windows 98 for PC
How to schedule system shutdown in windows xp
Go to Start >> Run type CMD and click Ok
in the command window
just use the AT command:
AT 9:00 SHUTDOWN -f
the schedule service must be running while using the AT command.
But normally it word well
Dec 30, 2008 | Microsoft Windows XP Professional
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
System not shutdown properly
try
start>run>cmd
shutdown /p
Jan 25, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
