My HP Scanjet 4070 Photosmart will not scan films using the TMA. It makes copies and scans pictures and documents OK. The TMA bulb is working. When attempting to scan Film or slides I get an error message saying that the scanner is not connected properly or is incorrectly installed. Surely this can't be the case as everything else works OK
  • iandonald Feb 28, 2009
    I Don't know, I haven't tried it yet.
  • iandonald Mar 01, 2009
    I've tried everything you suggest but to no avail.
    The scanner continues to work perfectly scanning text, or pictures, and copying, but I still get the error message when I attempt to scan slides or negatives. This message indicates that the scanner is not properly connected, improperly installed ,or there is a conflict somewhere.
  • 13,433 Answers
Hey, do you have all the software properly installed?
make sure here and get the drivers and software here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=391311&
Posted on Feb 28, 2009
  • 19,396 Answers
Ensure that you fit the mask correctly.
Eventually try reinstalling the scanner software.
  • Ginko
    Ginko Feb 28, 2009
    If you use the Transparent materials adapter, try doing the followinf, if the scanner is set on economy mode the lamp may not start:
    1 From the HP Director, click Settings.
    2 Select Scan Settings & Preferences.
    3 Select Scan Preferences.
    4 Click the Quality vs Speed tab.
    This will remove economy mode.
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    When I scan a negative, all I get is a picture of this negative which is useless. I thought that I could get the picture out of the negative that I scanned and save it so that I could get rid of the...
    With the scanner you should have received a cd "HP Scanjet 4800 Series HP IMage Zone Software. Mine is version 5.3 for Windows/8.4 for Mac OS v 10.2.
    I have this installed on a pc.
    When the button on the lid (2nd from left ) is pressed this opens a window HP Scanning.
    On this is an option to "Scan Negatives using the TMA (Transparent Materials Adaptor)" Select this and follow any further instructions concerning optons.
    Jan 20, 2011 | HP ScanJet 4850 Flatbed Scanner
    How do i scan a photo with hp deskjet f340 all in one?
    Place your document or picture on the glass. If scanning film, placethe 35 mm negative or slide in the special adapter provided by HP.Select the Scan Picture, Document or Film button depending on what youare scanning. Select the Make Copies button to copy the document orpicture directly. Click "Scan" and then "OK" to see the scan preview.
    Jan 08, 2010 | HP Deskjet F340 All-In-One Printer
    Can't scan PLEASE HELP!
    SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
    1. Load the slides or negatives in the TMA and place it on the scanner glass.
    2. Open Image Zone and click on Scan Picture to scan everything.
    3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
    4. Click on the first picture in the scan preview and make the following changes:
      • change the dust and scratch removal/sharpness to none
      • change the resolution to 72 dpi
    5. Click on the second picture in the scan preview and make the same changes described above.
    6. Click on the third picture and then the fourth picture and make the same changes.
    7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
    May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
    I am looking for instructions on this product.
    Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
    Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
    Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
    Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
    Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
    Step 6: In the Scanning from dialog box, click Change Settings.
    Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
    Step 8: Under Scan To select Save to file. Then click Scan.
    Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
    May 01, 2009 | Office Equipment & Supplies
    By scanning my negetive film 35mm,allways cuts a horizontal part.
    Try lower resolution while scanning & do set it at color settings. After preview then set color or monochrome......sodeep
    Mar 19, 2009 | HP Scanjet 4370
    HP Scanner 3570C-can not scan my slides
    According to the manual, you should always scan from the HP scanning software to scan slides using Scanjet transparent material adapter. There is no button that you can set for default slide scanning properties. This is shown on page 8 of the manual for the 3500 series scanners. The manual is available here: https://www.manualslib.com/manual/72847/Hp-Scanjet-2300c-Series.html?page=13#manual .
    Since the scanner works with pictures, make sure that the TMA adapter is plugged into the back of the scanner. Next open the software, HP Photo & Imaging Director. In most versions of Windows, press Start and look for the HP programs heading. Expand this to find the executable file. Alternatively, find the icon on the desktop or find the software in the file explorer (Program Files/HP/ on 32-bit versions, Program Files (x86)/HP) and then the appropriate sub-folder. Now try to scan the slides when they are loading in the adapter.
    I hope this helps. Please add a comment with your OS if you are still having problems. Some newer OS versions may have installed generic drivers for the ScanJet 3570C. The generic driver might not communicate with the TMA properly.)
    Jul 12, 2017 | HP ScanJet 3570cv Flatbed Scanner
    First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
    double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
    goodluck
    cheers
    Dec 22, 2008 | HP Scanjet 4850
    HP Photosmart 3210xi Scanning Issue
    no scan options refer to device documentation to troubleshoot
    Jul 12, 2008 | HP Photosmart 3210 All-In-One InkJet...
    Scanning negatives
    Are you saying
    The scanner worked with negative with XP but not with Vista?
    Uf so this is a drver problem
    Two thing to try- 1, Go to Programs/Accessories/system Tools Compatability Wizard and rest to XP then try.
    Or 2 Google for suitable Vista Driver
    Jun 11, 2008 | HP Scanjet 4070 Flatbed Scanner
    jasbo
    jasbo
