Question about Philips SA3025/37 Flash MP3 Player
This thing does not work always says ok to disconnect
  • 8,596 Answers
When the mp3 player is connected to the computer, the only message it will generally give you is "OK to Disconnect" - this is normal.
Once you disconnect the mp3 player from the computer, then you can find your music, listen to music, etc.
If you are getting the "OK to Disconnect" message when the mp3 player is already disconnected from the computer:
Reset the player first.
If that fails:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Posted on Mar 06, 2009
Back brake lights always on when transmission out of park
Check the wiring in the rear lamps. Look for corrosion int the plugs.
Mar 19, 2014 | 2002 Ford Focus
My remote entry will not work. I realiazed the battery was dead and replaced ,still not working, had new battery checked OK checked and recheck reasembling remote - did everything right. What else should I...
Try disconnecting the car battery and joining the two leads together and leave for a hour then reconnect the battery ,it works for the immobilisor failing which it needs reprogramming ,Sorry but according to my alldata book they can only be re-programmed using dealer diagnostic software ? but the battery disconnection may work as it has in the past for me but not always or i was just lucky
Nov 10, 2012 | Jaguar S-Type Cars & Trucks
Engine control computer needs to be replaced
Always disconnect the battery before replacing any computer parts.
And yes mileage should get better.
Jun 05, 2010 | 1993 Saturn SL2
We plugged in our amana distictions washer and it does nothing. it worked before i moved it now nothing
Moving sometimes throws things out or disconnects wiring.
Unplug machine from power source.
First thing that you can check is the lid switch. Open the machine lid and locate the lid swith. With a flat screw driver, push down on the lid switch and listen closly to see if you can hear a clicking sound.
If that is OK then the wiring in the machine need to be checked. Something may have come loose. If you are not confident checking the wiring throughout the machine, call a technician.
Always have the machine unplugged when checking wiring .
Good luck.
Ash
Oct 22, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Epson bx300f disconnects from internet
As things stand today, which might be different tomorrow, and having spent a lot of money on people who have tried to solve my problem, the last guy said that the problem was with BT and my service provider has had to sort it out with them. Today the Internet is OK. The one thing I have to try to remember is that one always has to turn a computer/printer or whatever OFF before trying something again. The correction is not made while leaving it on. It's useful to know that problems can be with BT and not always with one's appliances.
Aug 20, 2009 | Epson Stylus Multifunction Printer/...
After charging go gear- ok to disconnect screen is locked up
Make sure the hold switch is not engaged
Reset the player
Run a Repair in the Philips Device Manager
Jan 16, 2009 | Philips GOGEAR SA6045 MP3 Player
Cd stuck in cd player
Sometimes it requires a manual reset by disconnecting the wire harnest from the back the stock stereo that is that best solution before spending any money find some instruction in how to take out the Stock stereo.. Member Stereo shops are always trying to sell things ok just take some steps before paying somebody else, i think anybody could read some Basic Instruction..
Jul 24, 2008 | Nissan Xterra Cars & Trucks
No start
Replace battery cables.
Jul 06, 2008 | 1995 Toyota 4Runner
OK to Disconnect
Fixed it myself! Reset by holding down Menu and centre button until soft reset complete. All working fine now.
Feb 21, 2006 | Apple iPod nano
Philips SA3025/37 Flash MP3 Player Logo
114 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
