Question about Toshiba Satellite A135-S4527 Notebook
When power up lcd screen will not light up you can see program if you look hard some time it come right on other time you have to turn it back off and keep trying . external monitor work fine . if does appear it might stay on for hours or just a couple minute
    Problem Solver:
  • 17 Answers
It is most likely the LCD back light's inverter. They can be obtained for $15-$45(US) and are fairly simple to replace if you know how to remove the bezel from your laptop's LCD.
you can get more detail here:
http://hardware.slashdot.org/article.pl?sid=05/12/11/1727257
Posted on Feb 28, 2009
My kindle will not turn off
Did you try
Instructions
  1. Frozen Screen or Unresponsive Kindle
    • 1 Unplug the Kindle.
    • 2 Move the power button to the right and release. You should see a green LED light for two seconds.
    • 3 Move the power button to the right and hold for five seconds. The green light should blink three times and then the screen will go blank. Release the power button after it does.
    • 4 Turn the device back on by sliding the power button to the right and releasing it.
    Perform a Hard Reset
    • 5 Perform a hard reset if the previous steps are unsuccessful or if the Kindle screen is showing lines.
    • 6 Slide the power button to the right.
    • 7 Hold for 15 seconds.
    • 8 Recharge the battery if the device continues to be unresponsive.
    • 9 Restart the Kindle after charging.
Read more : http://www.ehow.com/how_7655306_reset-kindle-3g.html
Jul 29, 2014 | Amazon Kindle 3G
LG shows it will lose display in 3 seconds
hi the tv has detected a fault with the back lighting, now it could be a problem with the voltage to the back light or some of the leds in the back light have failed, it will turn off the back light when it finds a fault. behind the screen there is rows of leds on strips and they all light up when the screen is in use. and the main board knows they are lighting up by the voltage its using. when to many leds go out the voltage is too high so it will turn the back lights off to save them. also the same if the power board is not supplying the right volts. say the volts need to light the back screen is 64 volts and its only giving 62 volts the power is not right so it shuts down. same for if the volts go up to 64.5 volts it will do the same. hope this helps you under stand.
Jun 11, 2017 | LG 47 47LV5500 47 LCD TV
I have a Vizio Model XVT3D554SV TV that uses a bluetooth technology remote. I have been unable to get the MX 500 to learn from the TV remote and cannot find the code for the TV. I would like to use the MX...
2. Auto Scan With Three-Digit Number
You can also program your remote control by sending out a
series of Power Off commands for different brands stored
in the library by using the following steps. This is similar
to the first method, except it is easier to move through all
of the device codes for your device and make note of each
one that turns your device OFF.
1. Manually turn on the device you plan to operate.
2. Go to the SETUP mode by pressing both the MAIN and
ENT buttons simultaneously for three seconds.
3. Press the P-PRO button next to the LCD screen.
16
17
4. Programming the MX-500TMto Control Your Components
4. The remote will be flashing "SELECT BUTTON".
Press the device you wish to program. (For example, to
program TV, press the TV button.)
5. The remote will be flashing "FROM TABLE". Select the
device from which the scanned code will be selected.
(Important: If you have already relabeled your device
keys, your LCD screen will not look like the illustration
above. Select the appropriate LCD button for the "FROM
TABLE" using the labels as shown in the illustration on
page 11 of this manual. For example, if you have relabeled
AUX as LIGHTS, you would still push the bottom-left
button to access the AUX Code Table.
6. Point the remote control toward the component and
alternately press the UP (or DOWN ) button on the LCD
and the Power button. If the right code number is sent, the
component will turn off right after the code number is
transmitted.
(Please press the UP (or DOWN ) button within 20 seconds
of beginning programming, otherwise the remote will
revert to the SETUP menu, and then after a period of time,
it will go back to the MAIN device page.)
18
7. Confirm that it is the right code by pressing the Power
button. After you have confirmed that the right code is
entered, save the code by pressing the SAVE button on the
LCD.
8. Confirm that you entered the right code number that
matches your component by pressing other functional
buttons. If any of the buttons do not operate, as they
should, please repeat from Step 1.
9. Continue to program other components by repeating
from step 1 above.
10. You can press EXIT at any time if you do not wish to
proceed.
11. Exit from Preprogrammed mode by pressing the MAIN
button and then exit from the SETUP mode by pressing the
MAIN button once again.
Sep 14, 2011 | Universal Remote Control MX-500 LCD Remote...
I have a Compaq presario CQ61, an when i turn it on the screen is black other than some really dim writing i can hardly see. Help?
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 23, 2010 | Compaq Presario Notebook
Eee pc won't turn on (I think have already posted this,not sure)
Sounds like a classic case of hardware failure!!!!!!! possibly your motherboard, start by removing the battery, hard drive and optical drive.
disconnect the laptop monitor and connect the laptop to an external monitor.
remove the memory modules clean the brass contacts with a eraser and place back in the machine 1 at a time to check to see if they work, remember to plug in the AC power suppy, if you see the post screen then its a memory issue and you can then reconnect your laptop monitor to see if it lights up, if everything works but the monitor then its the inverter or backlight that has blown and is easily repairable saving you money on a brand new screen
Nov 13, 2008 | ASUS Eee 4G Notebook
LCD
First try this, right click on the desktop, click properties, open the screen saver tab, click the power button, then change the screen settings to never. If this doesn't work, then I'm afraid it's a hardware issue. Check the screen connections, connection to the back of the screen, screen to inverter, and screen to motherboard (under the keyboard), sometimes the connectors can work loose. If the connections are good, then the issue may lie with the inverter or screen itself. More than likely an intermittent problem with the inverter.
Jun 25, 2008 | IBM ThinkPad T30 2366 Notebook
The monitor light does not turn on!
Connect another external working monitor to the computer, if the other works then get lamps and inverter replaced.
May 25, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Toshiba Satellite A135-S4527 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
