Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
1 F in dispaly window
LG dishwasher LD 12AW2
Gaday i need some assistance with my inquiry.
Started dish washer tonight sound liked it drained water as always but could not hear any water entering the machine.
I left the power on and after a few minutes the finish cycle bell rang and 1F was displayed in the timer display.
Do know what part is needed to fix the problem the code 1F is telling me that something is broken or is not working proparly.
Regards Terry.
Well,i have the same problem.the solenoid doesn't open for the water to flow in.... but still working on the problem....
Posted on Feb 28, 2009
Dish washer has water in bottom & double beeps when trying to start
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 06, 2011 | LG 24 in. LD-12BW5 Free-standing...
My LG dishwasher - model LD-12AW2 has 'E1' alert & won't work
This sounds like a anti flood activation due to water leak / spill detection. This device (polystireen float and micro switch) at the base of the washer detects any water leak and stops the washing cycle once water leak activates the switch via the float. Check if any water at the base of washer is cuasing the float to activate the switch. Rectify any leak / spill (normally a pipe / clamp) and this should solve the problem.
Mar 26, 2010 | Dishwashers
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher not working showing 1F in timer display
I am not aware of an LG code 1F. But there is an error code "1E"
After you double check that the water valve is open that feeds the dishwasher, focus on the inlet valve (solenoid)
As you remove the inlet valve, if you see the screen is filled with gunk, clean it and retest.
Good Luck!
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG LD12AW2 Dishwasher overflowing
On the LG LD-12AW2 model, there is a float assembly just behind the wall where the water inlet port is located inside the unit.
When that float (or the micro-switch inside it) fails, water will continue to flow in without stopping . That causes the overflowing.
Post back here if you are looking for more specific guidance.
Good Luck!
Dec 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
Lg dishwasher LD-12aw2
IE is a INLET ERROR. Possible causes ¥ The Water Tap not opened.
¥ The Inlet Hose is kinked.
¥ The Filter of inlet valve clogged by
impure water.
¥ The Inlet Water Valve is normal ?
¥ The water pressure is very low.
( below 0.3 kgf/ )
Possible solutions ¥ Open the Water Tap.
¥ Repair the Inlet Hose.
¥ a) Close the Water Tap.
b) Unscrew the Inlet Hose (Inlet
Valve side)
c) Clean the Filter of Inlet Valve.
¥ Replace or repair the Inlet Valve.
Feb 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
Ie problem on lg dishwasher
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
231 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
