Question about Sony Ericsson W200i Cellular Phone
Keypad lock How i caxn make keypad lock .I need this with aperfect lock code.
But you haven't mentioned your phone's model and make.
Generally, you have to change the default password provided in the phone's manual or company service center/ customer care. Then you can produce whatever password you wish.
Be careful not to input wrong password repeatedly (3 times).
Posted on Mar 02, 2009
Don't know how to set key pad lock
Before locking the keypad first remember if the keypad lock is assigned with a security code.
Default value of the security code is normally 0000.
1. To lock the keypad first press the option key, then select the LOCK KEYPAD.
2. To unlock the keypad press the option key then press the "C" button.
You can check more lock/unlock optoons in the users manual, downloadable from this link. Read page 63 and on.
http://dl-www.sonyericsson.com/cws/download/1/150/669/1192984731/J230i__UG_R1a_EN.pdf
Sep 04, 2011 | Sony Ericsson J230i Cellular Phone
I have a schlage camelot leverset and i need to change the code. its a 4 digit code...How do i do this? thanks
No problem!
A quick note: The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-Lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock, which i noted above. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
Also, you will find "Keypad Programming Guide", etc. links which are PDF type files, giving you a "picture" of the print instructions.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck,and please provide feedback if this helps!
Aug 17, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
How can I lock the keypad?
Keypad lock: To lock the keypad press Menu then Star (*) key. To unlock the keypad press Unlock (Menu key) then Star (*) key. Press both keys in a fast way.
Hope this help and if helpful RATE please
Feb 22, 2011 | Nokia 6310i
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
How to change the keypad code on a 2001 mercury grand marquis
look for the permanent code on the plastic card in the owner manual packet. Or, pay dealer to extract code from computer.
Keyless Entry Keypad Code Programming NOTE: The system only allows one code to be programmed.
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code . The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
  1. Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
Feb 08, 2010 | 2001 Mercury Grand Marquis
Lock code on sony ericson w580i keypad lock
depending on we can't put the keypad lock on w580i while flicked closed keypad can be locked
Jul 07, 2009 | Sony Ericsson w580i Cellular Phone
How to lock the keypad with security code for sony ericsson?
I DONT WANT THE AUTOMATIC KEYPAD LOCK..BUT I WANT TO KNOW HOW TO MAKE KEYPAD SECURITY CODE SAME AS NOKIA..PLEASE HELP ME..
Dec 26, 2008 | Sony Ericsson S710a
Keypad lock with code
I am sorry but this function is not present with the Sony Ericsson K530.
Mar 20, 2008 | Cell Phones
Sony Ericsson W200i Cellular Phone Logo
80 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
