Question about Zanussi IZ12 Front Load Washer
Zanussi aquacycle 1000 start pause button
Washer panel lights do not come on.
The door light is on but the door does not lock.
When i press the program buttons they light up but nothing happens.
The washer just hangs.
    Scholar:
  • 106 Answers
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Posted on Feb 28, 2009
2 Suggested Answers
  • 150 Answers
SOURCE: zanussi aquacycle 1000 start pause button
investigate the water inlet cold water inlet valve
I have a zanussi 1600 aquacycle. We had a power cut then the machine wouldn't empty so I emptied it manually and now the door won't lock to start any programmes. Any suggestions??
turm the power off
then press in the two buttons on the left hand side while pressing them turn power back on turn selector to one oclock{if you have buttons to select programs press it } you should see the lights come on and move to different programs this is a test program to take it off test turn to off then turn anti clock wise
Feb 03, 2015 | Zanussi Washing Machines
Zanussi aquacycle 1200
Turn the machine to the off position. Unplug it and then plug it back in. Now try to restart the cycle. If this does not help find a local washer and dryer repair shop
Jan 24, 2014 | Washing Machines
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Aug 11, 2009 | Zanussi Washing Machines
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Feb 28, 2009 | Washing Machines
Zanussi IZ12 Front Load Washer Logo
623 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
